Issue with external proxy registered Jabber client making external calls
Chris Swinney
Level 5
Level 5
Hi All,
This is a bit of a continuation from a discussion started by thorstenn called Problem registering movi to VCSe (VCSc working). That thread was getting a little bloated an this is question has now moved on from that.
Essentially  we are setting up a test system in order to allow both Internal and  External Jabber users to register and make/receive calls. Whilst the  internal users register directly with the internal VCS-C, the external Jabber user will connect via the VCS-E that should proxy the registration (and all other requests) to the VCS-C.
Essentially it this type of scenario:
This is fine - External Jabber user can register with no issues.
The  problem comes with the sending of presence information to the external  Jabber client from third party devices (although this is OK from the  internal registered Jabber client), but more importantly the External  Jabber user cannot make calls to external third parties.
To  explain what I mean, I have diagrams the following call flows. The  first shows the call flows that work, the second shows what fails.
In  an attempt to get this working, and as this is a test system, I pretty  much rebuilt the dial plan search rule and pre-search transforms as per  the "Cisco TelePresence Video Communication Server Basic Configuration (Control with Expressway)" guide, (although I have NOT set a SIP domain on the VCS-E), but no joy.
We do have a VCS-E cluster, but we have even broken this so that there were was only one VCS-E --> one VCS-C, but no joy.
Essentially the search that is invoked on the VCS-C  find NO matching rules. Of course the similar search that happens when  the local client dial out works OK and is passed up the traversal zone.
The  only thing I could think of is a search coming from the traversal zone  cannot pass back up the same zone. However, In know other have this  scenario working (Paulo answer this for me in the other thread).
Following  is the are the search output from a call placed by a local client which  connects fine (please not I have edited IP addresses and aliases, but  have ensured they are consistent):
    Search (185)
        State: Completed
        Found: True
        Type: SIP (INVITE)
        CallRouted: True
        CallSerial Number: 4066b06a-e407-11e2-84e0-0010f31ed960
        Tag: 4066b20e-e407-11e2-b39a-0010f31ed960
        Source (1)
            Authenticated: True
            Aliases (1)
                Alias (1)
                    Type: Url
                    Origin: Unknown
                    Value: int-jabber@mydom.com
            Zone (1)
                Type: Local
            Path (1)
                Hop (1)
                    Address: IP_Add_Client:12177
        Destination (1)
            Alias (1)
                Type: Url
                Origin: Unknown
                Value: sip:swinster@otherdom.com
        StartTime: 2013-07-03 18:37:37
        Duration: 9.36
        SubSearch (1)
            Type: Transforms
            Action: Not Transformed
            ResultAlias (1)
                Type: Url
                Origin: Unknown
                Value: swinster@otherdom.com
            SubSearch (1)
                Type: Admin Policy
                Action: Proxy
                ResultAlias (1)
                    Type: Url
                    Origin: Unknown
                SubSearch (1)
                    Type: FindMe
                    Action: Proxy
                    ResultAlias (1)
                        Type: Url
                        Origin: Unknown
                    SubSearch (1)
                        Type: Search Rules
                        SearchRule (1)
                            Name: Expressway Query- E.164 and URI
                            Zone (1)
                                Type: TraversalClient
                                Protocol: SIP
                                Found: True
                                Duration: 9.34
                                Gatekeeper (1)
                                    Address: IP_Add_Exp1:7200
                                    Alias (1)
                                        Type: Url
                                        Origin: Unknown
Now is the search from the same VCS-C with a call comming from the Externally registered Jabber client (ie. via the Traversal zone)
    Search (184)
        State: Completed
        Found: False
        Reason: Not found
        Info: Policy Response
        Type: SIP (INVITE)
        CallSerial Number: ef77b7f8-e406-11e2-8d76-0010f31ed960
        Tag: ef746c6a-e406-11e2-be5a-0010f31ae17c
        Source (1)
            Authenticated: True
            Aliases (1)
                Alias (1)
                    Type: Url
                    Origin: Unknown
                    Value: ext-jabber@mydom.com
            Zone (1)
            Path (1)
                Hop (1)
                Hop (2)
                    Address: IP_Add_Client:12018
        Destination (1)
            Alias (1)
                Type: Url
                Origin: Unknown
        StartTime: 2013-07-03 18:35:21
        Duration: 0.01
        SubSearch (1)
            Type: Transforms
            ResultAlias (1)
                Type: Url
                Origin: Unknown
            SubSearch (1)
                Type: Admin Policy
                Action: Proxy
                ResultAlias (1)
                    Type: Url
                    Origin: Unknown
                SubSearch (1)
                    Type: FindMe
                    Action: Proxy
                    ResultAlias (1)
                        Type: Url
                        Origin: Unknown
                    SubSearch (1)
                        Type: Search Rules
The search rule that I believe should be invoke in the dial plan is the last one listed (800):
Priority State Rule name Protocol Source Authentication required Mode Pattern type Pattern string Pattern behavior On match Target Actions
48EnabledLocal Zone - no domainAnyAnyNoAlias pattern matchRegex(.+)@mydom.com.*ReplaceContinueLocalZone View/Edit
50DisabledLocalZoneMatchAnyAnyNoAny alias
50EnabledLocal zone – full URIAnyAnyNoAlias pattern matchRegex(.+)@mydom.com.*LeaveContinueLocalZone View/Edit
400EnabledExternal IP address search ruleAnyAnyNoAny IP address
ContinueTest Zone View/Edit
800EnabledExpressway Query- E.164 and URIAnyAnyNoAny alias
The only other thing we have tried is  setting up a second traversal zone so essentially there is one zone  routing in and one routing out. This did appear to make help as the  calls were then connect although we still had no presence info from  third parties, and this managed to cause Jabber to crash inconstantly!
Sorry for the long post but I'm sure a some of you will still want further info, so please let me know what I can offer.
Chris
Message was edited by: Chris Swinney  Changed images and search histories to reflect domain distinction between endpoints
31 Replies 31
Hi Adnan,
We worked round the issue. We no longer Proxy the registration, but register the user directly to VCS-E.
We actually have enabled Provisioning on the VCS-E to allow TMS to push user to the device although actual provisioning takes place on the VCS-C. You have to run some command line rule to delete some SIP routes on the VCS-E that are put in place through the act of adding the Provisioning Licence, and as such and can bet the bank that this is NOT a Cisco recommended practice (.... but works great for us is out situation).
However, we still have issue with external users placing calls, but this is more to do with where that external user maybe located - i.e. are they inside another institution behind another cooperate firewall. Essentially, whilst the Jabber user may be able to register to the VCS-E, if they place a call they will NOT receive  any media as UDP packets from the VCS-E are blocked at the other institutions firewall. This could be resolved if Jabber where able to utilise the firewall traversal system built into the VCS-E - essentially creating an outbound connection from Jabber to the VCS-E to then enable return media via this established link, but it doesn't.
I did post about this as well (https://supportforums.cisco.com/thread/2235817, although this post starts out about a question with reagrd to another issue), and have asked for a feature request to be submitted by out Cisco Partner - which I hope they have done. Ishan - I would love to see this resoved in x8.1!!!
ALthough I would just love to see x8 first ................
