02-23-2012 08:14 PM - edited 03-17-2019 10:51 PM
I am setting up Movi but I can't set up TMS Agent replication with VCS Control.
I'm trying to enable provisioning in my TMS. But after the VCS is inserted, in TMS in Systems > Navigator, selecting the VCS and under TMS agent tab
check the option "Enable TMS Agent Data Replication:" after that the Activity status for TMS Agent show this message: "Unable to connect to the TMS agent on this VCS" and the option "Enable TMS Agent Data Replication:" it's disabled.
any advice?
02-23-2012 08:34 PM
Hi Nelson,
Please check some key points:
- you should be able to perform the forward and reverese lookup for the FQDN from VCS and TMS vice-versa.
- check if you any windows firewall ON or any other firewall in between.
- check for port 389 and 4444 should be allowed to communicate to VCS in case if firewall
- check local TMS agent health it should be all GREEN'S
- alternatively if its a new VCS and you are enabling the replication for the first time then you can use the command
tmsagent_destroy_and_purge_data, The command needs to be run through root prompt of VCS
- Once the result is successful then reboot the VCS and once it comes online, try to
enable the replication again.
Alok
02-23-2012 08:48 PM
Hi Alok,
Here my answer about your advices:
Answer: VCS and TMS are configured with the same DNS sever. I have ping to the FQDN names for both and it worked fine.
Answer: Boths VCS and TMS are in the same subnet.
- check for port 389 and 4444 should be allowed to communicate to VCS in case if firewall.
Answer: like the before item.
Answer: Yes.
Answer: Yes, I am setting up the VCS for new implementation. and i will try this advice.
i will send you the results.
Thank you.
02-28-2012 01:54 PM
Hi, Alok i have executed the command after that the replication worked fine.
thank you for your advice
I have another issue, but with cisco Movi (Jabber 4.3), movi client can´t get phone book from the TMS, any idea to fix it?.
02-28-2012 05:03 PM
Hi Nelson
Make sure that the configuration in the provisioning directory is correct. The config should be "Phone book server URI" not URL the uri is phonebook@sipdomain.com. When this is correct go to the phonebook and click access control. Check the boxes for groups you want to see phonebooks and save. Remember for the provisioning phonebook to show entries the other users must have logged in so they get associated with a device.
Hope this helps.
/magnus
03-13-2012 07:39 PM
Hi Magnus, i have configured the Server URL in provisioning template and it works fine.
Thank you.
