08-10-2015 05:56 PM - edited 03-18-2019 04:50 AM
Hi All,
I believe that Jabber Guest can only call a device that is registered to the CUCM. However, if the number or SIP URI had a route pattern and the device was actually registered to a VCS-Control - would this work? Has anyone done this?
Robert
08-10-2015 08:15 PM
Take a look at the the discussion jabber-guest-vcs-control-registered-endpoint-and-mcu, it might have what you're looking for.
Also, there is a dedicated section of the forums for Jabber Guest, suggest you move your question there so others can help.
08-11-2015 06:07 PM
08-11-2015 05:27 AM
When your Jabber guest points to a sip uri that can be reached by the UCM to wich the JG server points, the call will establish.
I have several cases where the JG link points to a VCS registered Device, SIP or H.323.
08-11-2015 06:07 PM
Thanks!
