jabber guest server
Hi ,
can someone help me with good document to deploay that with expressway ?
the doc in the internet are so pore .
Manish Gogna
Hi Sharon,
Please deploy as per the Jabber Guest deployment guide below
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/jabber/Guest/10_5/icg/JABC_BK_JA306F08_00_jabber-guest-install-and-configure/JABC_BK_JA306F08_00_jabber-guest-install-and-configure_chapter_010.html
Manish
Hi ,
Thanks for that . So i install the jabber + exp C and exp E .
Q : for the cert in the jabber what type of cert the local CA need to do à web server ?
Q : for the cert in the expressway it is the seam cert like i will deploay for MRA ?
in the doc it just say "send it to the ca in my case and after you get it back upload it to the server" .
