Jabber Video for Telepresence having issue with Video. When try to open self-view and making call getting either blank screen or transparent screen.
eric.simbulan
-Windows 7 Enterprise 64-bit
-Lenovo Thinkpad T4602
Joe Vallender
Level 3
Level 3
Are you using an embedded camera?  It sounds like Jabber isn't recognizing the camera properly. Can you check for driver updates (camera/video/display)?
Does a USB camera work?
I recall that embedded cameras on some laptops might have applications running that hold control of the camera, blocking Jabber from using. We found that installing a camera sharing application drivers like http://www.driverscape.com/download/arcsoft-webcam-sharing-manager allows multiple applications to access the camera simultaneously.
