Latest firmware for Tandberg 770 mxp and mxp 85 Edge
traumen
Hello, there are two Tandberg 770 MXP (TTC7-08) codecs, firmware F8.0 and mxp 85 Edge (TTC7-14) on firmware F7.2 - how to get or where to download the latest firmware for these codecs.
The codecs themselves work, Feature and Bandwdth keys are all there (spelled out).
Thanks!
The Mentioned   hardwares  got EOL on 2015, You won't find the software on Cisco portal.
The only option which exist will be Google search.
Response Signature
traumen
if someone has a link to download the firmware for these codecs.
I tried to find it in googl - it didn't work
Getting access to the firmware file by itself will not help as you will also need a Release Key for the newer software version.   The only place you will be able to get one of these is from Cisco.   As they are End of Support devices, you are not likely to be able to get much assistance with this at all unless you speak really nicely to one of your local Cisco Account Managers - they may have access to people who have access to the old tools to generate a Release Key for you - but you would be much better off replacing the old device with something newer and supportable.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
