lock down data on a voice network
We have CUCM voice infrastructure and we need to give access to voice network on a remote site where we dont need any data access(no PCs on site only phones).any suggesions for Securing the network?possibly locking it down only for voice
remote site will be connecting through Microwave
Thanks in advance
***Please rate all the useful posts***
-Prabath
2 Accepted Solutions
Ray Watkins
You can do the following to help with physical security:
disable switchport on the phones
shutdown all ports on the switch not in use by a phone or uplink
You can create an ACL on the router that blocks all traffic on the voice vlan except for RTP and signaling. This will block any traffic that is generated
by the workstation.
In addition to Mr. Watkins suggestions you might want to consider port security.
Ray Watkins
by the workstation.
