I encountered problem on Jabber users logging in via VCS Expressway as external server.
Login error is "Wrong username/password or domain".
Internal Jabber users using same credential can log in successfully via VCS Control as internal server and can make calls. No issue on internal.
External endpoints/codec can register on VCS Expressway using SIP and can make call to internal endpoint registered on the VCS Control.
SIP domains are both configured on the VCS servers.
The VCS servers are both running on X7.2.2 and Jabber users are provisioned via TMSPE running TMS 14.1.1.
What is the possible cause of the problem??
Thank you.
Acevirgil
