Loosing NTP
WillyT
After reboot my Room kits loose NTP connection. When I web into device it shows that its on AUTO for NTP.  I have switched over to Manual and have entered the IP for our NTP server. After a while it looses connection and defualts to AUTO.  At times Auto input is blank but when I register a new system it pulls a default Tanberg info that dosent work.
b.winter
Standard question: Have you tried a different / newer Firmware version for the device?
