Macros and Cloud Registered Devices
lfulgenzi
Level 7
Level 7
I was thinking about creating a macro to prompt a user for a 5 digit number, then to append @acme.com to it and place a SIP call.
So, two questions:
1) Are macros supported on cloud (webex)  registered room devices, eg Roomkit mini?
2) is what I’m asking possible?
thanks!
Ashish Patel
Yes it should be possible. You need to create a user to allow access to the cloud registered endpoint. See these links
Good training material on customisation here https://developer.cisco.com/docs/prog-coe_resources/#!focused-learning/collaboration
Macro samples here https://github.com/CiscoDevNet/roomdevices-macros-samples
ashish
Response Signature
Ashish Patel
ashish
Response Signature
Thanks @Ashish Patel
When you say ‘create a user’ do you mean create a local user on the device?
Also, it seems that the first link is broken? I get a 403 Forbidden error.
Thoughts?
Also, when I go to github, specifically the postman section:
https://github.com/CiscoDevNet/postman-xapi
it has a note regarding using admin user for on-prem vs integrator user for cloud registered.
I was expecting a similar note or distinction for the macro use but do not see that.
So, do I use an admin account for local macros?
I found the step by step intro which talks about setting up the integrator account. And specifically mentions on-prem vs. cloud registered.
I think I’ll go through those. But if anyone has any pointers or gotchas they ran into, that would be great.
This is the step-by-step I’m talking about.
https://developer.cisco.com/learning/lab/collab-xapi-intro/step/1
