MAKE A CALL FROM BROWSER ON MXP3000
Chet Cronin
Level 4
Level 4
What is the dial syntax when making a call from the browser on an MXP3000???
Example:  Select "call" and enter the IP or Alias in the first number window.  No issue.
But when calling into the Codian and then selecting the conference number I have issue.
Example:  Codian is 6004022000
Conf ID:  4532
Local using hand held remote I would dial the number and then enter the 4532# to get into the room.
From Browser:
There are three windows on the call webpage, example
first address  6004022000
second address
subaddress
Question is what special characters and where would I put the conf ID to enter the room using the web browser.
Any ideas ???
VR
Chet
Chet Cronin
Patrick Sparkman
It's been awhile since I've touched an MXP endpoint, but I don't think you can send DTMF via the web interface.  Just like the TC/CE based endpoints, you can't insert DTMF into the dial string, so that isn't an option either.
You can send DTMF via the API though:
xCommand DTMFSend Value
Patrick Sparkman
