07-21-2017 06:07 AM - edited 03-18-2019 01:19 PM
What is the dial syntax when making a call from the browser on an MXP3000???
Example: Select "call" and enter the IP or Alias in the first number window. No issue.
But when calling into the Codian and then selecting the conference number I have issue.
Example: Codian is 6004022000
Conf ID: 4532
Local using hand held remote I would dial the number and then enter the 4532# to get into the room.
From Browser:
There are three windows on the call webpage, example
first address 6004022000
second address
subaddress
Question is what special characters and where would I put the conf ID to enter the room using the web browser.
Any ideas ???
VR
Chet
Solved! Go to Solution.
07-21-2017 12:04 PM
It's been awhile since I've touched an MXP endpoint, but I don't think you can send DTMF via the web interface. Just like the TC/CE based endpoints, you can't insert DTMF into the dial string, so that isn't an option either.
You can send DTMF via the API though:
xCommand DTMFSend Value
07-21-2017 12:04 PM
