Make use of traversal call instead of Non-traversal on Cisco VCS-C
Elie Sbat
I have a Cisco VCS Control currently running 20 non-traversal and 100 traversal license. I need once I initiate a session from Cisco Jabber client to one of the cameras (Studios) . I want the VCS to consume a traversal call license ?
Is this possibe ?
2 Accepted Solutions
Magnus Ohm
If you enable interworking and call from jabber on sip to an H323 endpoint. SIP<-> h323 will consume a traversal
Lisence.
/Magnus
Magnus Ohm
Ok on the c60 disable sip. Register it on h323 and call it from the jabber client. If you use an e164 alias i think you need a search rule that adds the @domain.com as a suffix. If you dont type this in manual when you are making the call.
/Magnus
6 Replies 6
Magnus Ohm
Lisence.
/Magnus
let me tellyou the setup. I have a Cisco VCS-C and Tandberg Camera. Codec C60 .
I enables Interworking on Cisco VCS but on Cisco Jabber there is no option choose the protocol.
The camera is running on SIP.
Magnus Ohm
/Magnus
Magnus,
how to make it register on H232 ? where to find the alias ? I am very novice in Teleresence
I know how to reach to H232 configuration an SIP but there what field I hve to fill ?
It worked
Tomonori Taniguchi
If you enable the media encryption policy, media will go through VCS and call will treat as traversal call as well.
This will work even camera-studios device registered on VCS-C as SIP UA (media encryption policy works for SIP call).
For more information about media encryption policy, please take a look page 6-11 of https://supportforums.cisco.com/docs/DOC-26316 and X7.2 administrator guide.
