10-06-2014 10:36 PM - edited 03-18-2019 03:29 AM
Hi all,
I'm trying to manage an SX20 via API for an application development.
In "codec-sx20-api-reference-guide-tc72.pdf" Page21, how to POST xml file to a codec is mentioned.
But it doesn't work.
Is my procedure incorrect?
URL => http://<ip-address of SX20>/putxml
Request =>
POST /putxml HTTP/1.1
Content-Type: text/xml
Connection: close
<Configuration>
<SystemUnit>
<Name>newName</Name>
</SystemUnit>
</Configuration>
Reponse => " (417) Expectation Failed"
Best Regards,
Kotaro
10-07-2014 02:13 PM
Hi Kotaro, make sure first that XMLAPI is enabled in the endpoint's configuration
10-09-2014 10:37 PM
Thank you thobonho2,
I enabled XMLAPI but result is same.
Is there any configuration I should check?
Kotaro
10-10-2014 02:42 AM
I forgot to mention it, but you must reboot the endpoint in order to get the service started actually.
Also, to discard any problem with the application you're developing, try using HTTP GET method instead. Just copy and paste this url in your browser:
http://<ip>/formputxml?xmldoc=<Configuration><SystemUnit><Name>newName</Name></SystemUnit></Configuration>
If you get this working, you know the codec's API is enabled and running fine, and you can focus on your application.
