Management of EX90, registerd to CUCM
stijnlaureys
I've got an EX90 running TE6.0 registered to cucm (8.6).
The cucm is connected with TMS so i can add them and schedule conferences with the cucm registered systems.
But i'm looking for a way to manage the EX90.
With tms, templates can be pushed with all possible settings.
How can this be done when a system is registered on a cucm?
For example: i want to push the facility service settings.
Is this perhaps a limitation?
Stijn
Kjetil Ree
TMS does not push settings to Cisco Unified CM registered endpoints (with the exception of the feedback address TMS uses for call monitoring).
This is a deliberate decision, so I'm not sure if I would describe it as a "limitation".
Best regards,
Kjetil
I know it's not supported.
I'm looking for a way via CUCM. Can i push settings like the facility service?
Or is there a limit which can be pushed via CUCM?
