ATTENTION: We are currently working an issue with posting. Thank you for your patience while we work on a resolution.
Marking down VC from AF41 on the LAN to AF31 for the WAN
jayesh.shah
How do I 'mark-down' VC calls from AF41 (COS 4) on the LAN to AF31 (COS 3) for the WAN provider? (The WAN provider is looking at AF31 and designating that as Video traffic when it connects to their network). Do I do this on the router or on the switches? Are there any sample configs available?
Thks
Jay
spremkumar
Level 9
Level 9
hi
if your switch is already marking this VC calls as COS 4 and sending it to your router then you can define a class map matching all the cos4 marked traffic and set cos 3 under the policy map while remarking.
Place the service policy on the outgoing interface facing your SP side...
just try this out and revert back how it goes...
regds
Would you have a sample of how do this?
do find some sample config lines which can help u out..
class-map match-any test
match cos 4
policy-map test
class test
set dscp af31
Apply this policy map under your wan interface connected to the remote site.
apply it in the outbound direction...
interface serial 1/0
service-policy output test
hope this helps ...
regds
