10-11-2018 09:32 PM
Hi all,
I am desiging a system with Expressway-C as H323 registration. We have 1000 endpoint Polycom, and want to register to expressway-C. It is possible but in expressway datasheet said: expressway can process 100 video call currently.
My question: this capacity is for firewall traversal calls or for all calls type?
Solved! Go to Solution.
10-14-2018 07:21 PM
The maximum number of calls in a cluster is 4x the maximum of an individual. You can cluster up to 6 expressways to give you the additional resiliency in your deployment (ie you can have up to two of them go off-line for any reason without affecting your call capacity).
Please remember to mark helpful responses and to set your question as answered if appropriate.
10-14-2018 07:05 PM
The concurrent call capacity will depend on your deployment. If you deloy a "large" expressway instead of the standard "medium" deployment, the call capacity raises up to 500 video calls from the "standard" 100.
If you then cluster multiple expressways, this can increase the maximum call capaity up to 4 times, ie with up to 6 expresways in a cluster, you can have resiliency in your deployment and up to 2000 concurrent video calls (see "Clustered Expressway capacity" in the Expressway X8.9 Data Sheet).
10-14-2018 07:16 PM
10-14-2018 07:21 PM
10-14-2018 07:51 PM
