07-25-2012 06:57 AM - edited 03-17-2019 11:31 PM
Can anyone tell me if the Codian MCUs supports publishing presence to a VCS for individual conferences i.e. 70000@domain.com, 70001@domain.com, etc..?
We used to use OCS and if I recall correctly I'm pretty sure we could see the presence of meeting rooms (added to AD as users) from the OCS client. Is it possible to have the same experience via a Jabber/Movi client? I've tried looking in the documentation but I can't find anything!!
Solved! Go to Solution.
07-30-2012 04:43 AM
Darren,
what search rules have you configured on the VCS-E which are targeting the traversal zone going towards the VCS-C?
The 404 Not found could also mean that the URI specified in the Request-URI of the PUBLISH does not match any of these search rules.
- Andreas
07-30-2012 05:23 AM
Hi, if that was the case would I be correct in assuming I wouldn't get presence from the MCU's main registration? Presence for this registration is published fine.
The search rule configured is (.*)@domain.com.
07-30-2012 05:43 AM
Darren,
that's correct, you shouldn't be seeing the presence for the MCU AA in that case either, assuming the domain for both URI's are the same (So that the search rule would match both URI's).
Please check your PM inbox as I have sent you a message there.
- Andreas
07-30-2012 06:02 AM
replied via PM
_______________________________
This is now resolved with the help of Andreas, after analysing the logs he found the transform below was breaking the presence.
(7....)@domain.com was being replaced by \1
