MCU Rebooting
nikhil.kmr
Hi Everyone,
I have an issue with one of the MCU ( 4510), at our customer place, where it is automatically rebotting in every 30 seconds, i have checked the Health of the MCU and it is good.
but i can see its running on very old version, but because the MCU is rebotting of every 30 secs,im not able to upgrade it.
Can anyone tell any alternative solution, Attaching the event Logs for your reference.
Nikhil
10 Replies 10
Patrick Pettit
Hi Nikhil.  It would be best to hook up the console to the MCU and see where in the boot process its failing.  You should capture the text to an output file for review.
Steps to hook up the console:
http://www.cisco.com/en/US/docs/telepresence/infrastructure/articles/cisco_telepresence_connect_console_port_kb_6.shtml
Steps to kupgrade the unit:
http://www.cisco.com/en/US/docs/telepresence/infrastructure/articles/cisco_telepresence_upgrade_using_external_compact_flash_kb_16.shtml'
If you cant' get the unit to upgrade, would probably best to open SR for TAC review.  You will neeed to capture the boot at least twice here to see if the failure is the same.  Then you need to console the kupgrade process as well.
VR
Patrick
   In addition to that, if possible please make sure that you upload the diagnostic file as well once the TAC SR is opened.
    We might need to RMA the unit due to corrupted intrenal CF , however we need to see this in the serial output / diagnostic file to confirm
i had a same issue ..
opened a TAC case .
equipment was suggested for RMA.
now its working fine .
i dunoo wt was really wrong .i even upgraded the software and even TAC forwrded my request to senior staff ...still they couldnot recover it ... so it was RMA'ed
Hi Christian,
Im Attaching the output from the MCU through Serial Cable Kindly Suggest what could be the reason here for MCU rebotting again & again
Motherboard serial number -
Slotmask : 00000008
03 -
Devmode : 00000000
Trying dos1:kupgrade
error opening source file dos1:kupgrade
Trying dos0:kupgrade
error opening source file dos0:kupgrade
Trying dos0:netbsd
copying dos0:netbsd to md0:00000000............................................002be856 bytes copied
Image version : netbsd_home:/bin/netbsd-ramdisk-32M
fd=7
loadelf fd=7 Elf_Ehdr=0xefffe58 marks=0xe0c632c flags=0000003f
loadelf line 78
loadelf line 86
loadelf line 93
loadelf line 150
loadelf line 165
loadelf line 178
loadelf line 200
loadelf line 200
ok
MARK[0] = 00090000
MARK[1] = 00090000
MARK[2] = 00000001
MARK[3] = 0044f8dc
MARK[4] = 00490444
calling ksyms_init (startkernel=0x090000 endkernel=0x49b000 edata=0x0 end=0x7f454c46 startsym=0x44f8dc endsym=0x490444
ksyms_init
Loaded initial symtab at 0x44f8dc, strtab at 0x471db0, # entries 8180
Copyright (c) 1996, 1997, 1998, 1999, 2000, 2001, 2002, 2003
    The NetBSD Foundation, Inc.  All rights reserved.
Copyright (c) 1982, 1986, 1989, 1991, 1993
    The Regents of the University of California.  All rights reserved.
NetBSD 1.6ZG (ZAPHODCONF_COMMON) #0: Fri Jul 27 18:34:27 BST 2012
root@build-freebsd-rel1.lal.cisco.com:/stripe/builduser/XQJROOCR/netbsd/src/sys/arch/marvin/compile/obj/ZAPHODCONF_COMMON
total memory = 240 MB
avail memory = 215 MB
using 3072 buffers containing 12388 KB of memory
sysctl_createv: sysctl_create(cacheinfo) returned 17
mainbus0 (root)mainbus_attach
eumbbus_match: cpu eumbbus
cpu0 at mainbus0: Version 0x8081 (Revision 0x1014), ID 0 (primary)
cpu0: HID0 90c000
config_found cpu done
eumbbus_match: eumbbus eumbbus
eumbbus0 at mainbus0eumbbus_attach
eumbbus_submatch
com0 at eumbbus0com_eumbbus_attach
bus_space_map(00300eac, fc004500, 00000008..)
sc_ioh=fc004500
com_attach_subr iot=00300eac ioh=fc004500 type=00000000 freq=06baa800
: ns16550a, working fifo
com0: console
intr_establish 00000014
00011120
eumbbus_submatch
com1 at eumbbus0com_eumbbus_attach
bus_space_map(00300eac, fc000000, 00000008..)
sc_ioh=fc004600
com_attach_subr iot=00300eac ioh=fc004600 type=00000000 freq=06baa800
intr_establish 00000015
00011140
about to setup pci
calling pci configurepci_conf_interrupt bus 0x00000000 dev 0x00000000
line=0xff
pci_conf_interrupt bus 0x00000000 dev 0x00000010
line=0x00
pci_conf_interrupt bus 0x00000000 dev 0x00000011
line=0x01
pci_conf_interrupt bus 0x00000001 dev 0x00000003
line=0x0c
pci_conf_interrupt bus 0x00000002 dev 0x00000000
line=0x0f
line=0x0f
configure_bus 0
configure_bridge 1
Bus 1 mem_base=80000000 mem_limit=80ffffff
configure_bus 1
configure_bridge 2
Bus 2 mem_base=80000000 mem_limit=807fffff
configure_bus 2
eumbbus_match: pci eumbbus
pci0 at mainbus0 bus 0
pci0: i/o space, memory space enabled
aceride_match 00061057
vendor 0x1057 product 0x0006 (host bridge, revision 0x14) at pci0 dev 0 function 0 not configured
aceride_match 165314e4
bge0 at pci0 dev 16 function 0: Broadcom BCM5705M Gigabit Ethernet
pci_mapreg_map 00000010 type 4 tag=0xd006b2b4 h=0xd006b2b0
pci_mem_find
bge0: ASIC BCM5705 A3, Ethernet address 00:0d:7c:00:69:86
brgphy0 at bge0 phy 1: BCM5705 1000BASE-T media interface, rev. 2
brgphy0: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseT, 1000baseT-FDX, auto
bge1 at pci0 dev 17 function 0: Broadcom BCM5705M Gigabit Ethernet
pci_mapreg_map 00000010 type 4 tag=0xd006f2b4 h=0xd006f2b0
pci_mem_find
bge1: ASIC BCM5705 A3, Ethernet address 00:0d:7c:00:69:87
brgphy1 at bge1 phy 1: BCM5705 1000BASE-T media interface, rev. 2
brgphy1: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseT, 1000baseT-FDX, auto
aceride_match ac28104c
ppb0 at pci0 dev 20 function 0: vendor 0x104c product 0xac28 (rev. 0x02)
pci1 at ppb0 bus 1
pci1: i/o space, memory space enabled
aceride_match 905610b5
vendor 0x10b5 product 0x9056 (miscellaneous bridge, revision 0xba) at pci1 dev 3 function 0 not configured
ppb1 at pci1 dev 6 function 0: vendor 0x104c product 0xac28 (rev. 0x02)
pci2 at ppb1 bus 2
pci2: i/o space, memory space enabled
aceride_match ac55104c
cbb1 at pci2 dev 0 function 0: vendor 0x104c product 0xac55 (rev. 0x01)
pa_iot=00300d9c pa_memt=00300eac pa_flags=00000003 pa_bus=00000002 pa_device=00000000
rbus_new_body: [2000, 2800] type dedicated name [rbus root]
base=80000000 offs=00000000 limit=fe000000 extent=0x331450
extent `iomem' (0x80000000 - 0xfdffffff), flags = 0x3
res=80000000
rbus_new_body: [80004000, 80008000] type dedicated name [rbus root]
sock_base=80000000
pci_mapreg_map 00000010 type 0 tag=0xd005ca48 h=0xd005ca4c
pci_mem_find
cbb0 at pci2 dev 0 function 1: vendor 0x104c product 0xac55 (rev. 0x01)
pa_iot=00300d9c pa_memt=00300eac pa_flags=00000003 pa_bus=00000002 pa_device=00000001
rbus_new_body: [2800, 3000] type dedicated name [rbus root]
res=80001000
rbus_new_body: [80009000, 8000d000] type dedicated name [rbus root]
sock_base=80001000
pci_mapreg_map 00000010 type 0 tag=0xd005c848 h=0xd005c84c
pci_mem_find
pci_intr_map pin=0x03 line=0x0f
intr_establish 0000000f
000103e0
cbb1: interrupting at irq 15
cardslot1 at cbb1 slot 1 flags 0
cardslot1 attaching CardBus bus...
cardbus1 at cardslot1: bus 3 device 0
cardslotattach: found cardbus on cardslot1
pcmcia1 at cardslot1
cardslotattach: found 16-bit pcmcia bus
cardbusattach: 16-bit card found
cardslot_event_throw: an event 16-bit Card inserted comes
000103e0
cbb0: interrupting at irq 15
cardslot0 at cbb0 slot 0 flags 0
cardslot0 attaching CardBus bus...
cardbus0 at cardslot0: bus 4 device 0
cardslotattach: found cardbus on cardslot0
pcmcia0 at cardslot0
mainbus attach done
kthread_create
biomask 8000 netmask 8000 ttymask 8000
*** dll_stat_reg=91f000c1
ccdattach
Kernelized RAIDframe activated
i2c_attach
demux_table=0xf100000:0xf23ffff(00140000)
mbtrace=0xf200000:0xf5fffff(00400000)
board_init
pcmcia card attach
card ready
rbus_space_alloc: addr 0, size 1000, mask fff, align 1000
pcmcia1: CIS version PCMCIA 2.0 or 2.1
pcmcia1: CIS info: SILICONSYSTEMS, VER2.00
pcmcia1: Manufacturer code 0x0, product 0x0
pcmcia1: function 0: fixed disk(ata), ccr addr 200 mask f
pcmcia1: function 0, config table entry 0: memory card; irq mask 0; memspace 0-7ff; maxtwins 1; mwait_required rdybsy_active powerdown
pcmcia1: function 0, config table entry 1: I/O card; irq mask ffff; iomask 4, iospace 0-f; memspace 0-7ff; maxtwins 1; rdybsy_active io8 io16 irqshare irqpulse irqlevel powerdown
pcmcia1: function 0, config table entry 2: I/O card; irq mask 4000; iomask a, iospace 1f0-1f7 3f6-3f7; memspace 0-7ff; maxtwins 1; rdybsy_active io8 io16 irqshare irqpulse irqlevel powerdown
pcmcia1: function 0, config table entry 3: I/O card; irq mask 4000; iomask a, iospace 170-177 376-377; memspace 0-7ff; maxtwins 1; rdybsy_active io8 io16 irqshare irqpulse irqlevel powerdown
pcmcia1: function 0, config table entry 7: I/O card; irq mask 4000; iomask a, iospace 170-177 376-377; memspace 0-7ff; maxtwins 1; rdybsy_active io8 io16 irqshare irqpulse irqlevel powerdown
wdc1 at pcmcia1 function 0function type 00000000
card ready
memory mapped mode
wdc pcmcia memmode, noirq
atabus1 at wdc1 channel 0
pcmcia card attach
card ready
pcmcia0: CIS version PCMCIA 2.0 or 2.1
pcmcia0: CIS info: SILICONSYSTEMS, VER2.00
pcmcia0: Manufacturer code 0x0, product 0x0
pcmcia0: function 0: fixed disk(ata), ccr addr 200 mask f
pcmcia0: function 0, config table entry 0: memory card; irq mask 0; memspace 0-7ff; maxtwins 1; mwait_required rdybsy_active powerdown
pcmcia0: function 0, config table entry 1: I/O card; irq mask ffff; iomask 4, iospace 0-f; memspace 0-7ff; maxtwins 1; rdybsy_active io8 io16 irqshare irqpulse irqlevel powerdown
pcmcia0: function 0, config table entry 2: I/O card; irq mask 4000; iomask a, iospace 1f0-1f7 3f6-3f7; memspace 0-7ff; maxtwins 1; rdybsy_active io8 io16 irqshare irqpulse irqlevel powerdown
pcmcia0: function 0, config table entry 3: I/O card; irq mask 4000; iomask a, iospace 170-177 376-377; memspace 0-7ff; maxtwins 1; rdybsy_active io8 io16 irqshare irqpulse irqlevel powerdown
pcmcia0: function 0, config table entry 7: I/O card; irq mask 4000; iomask a, iospace 170-177 376-377; memspace 0-7ff; maxtwins 1; rdybsy_active io8 io16 irqshare irqpulse irqlevel powerdown
wdc0 at pcmcia0 function 0function type 00000000
card ready
memory mapped mode
atabus0 at wdc0 channel 0
wd1 at atabus1 drive 0:
wd1: drive supports 1-sector PIO transfers, LBA addressing
wd1: 248 MB, 994 cyl, 16 head, 32 sec, 512 bytes/sect x 508928 sectors
wd0 at atabus0 drive 0:
wd0: drive supports 1-sector PIO transfers, LBA addressing
wd0: 248 MB, 994 cyl, 16 head, 32 sec, 512 bytes/sect x 508928 sectors
card ready
wd1: no disk label
card ready
howto 2 bootdev 0 boot device: wd0
root on wd0a dumps on wd0b
card ready
about to call domountroothook
about to call vfs_mountroot
card ready
card ready
rtcinit()
Cold Boot - power down at 17:48:38.00 14/05/13
Time is now 17:50:24.86 14/05/13
root file system type: ffs
May 14 17:50:27 init: /etc/pwd.db: No such file or directory
fsck: Cannot open `/etc/fstab': No such file or directory
** /dev/rwd0b
** Phase 1 - Read and Compare FATs
** Phase 2 - Check Cluster Chains
** Phase 3 - Checking Directories
** Phase 4 - Checking for Lost Files
16 files, 62502 free (31251 clusters)
** /dev/rwd0d
** Last Mounted on /rdwr
** Phase 1 - Check Blocks and Sizes
** Phase 2 - Check Pathnames
** Phase 3 - Check Connectivity
** Phase 4 - Check Reference Counts
** Phase 5 - Check Cyl groups
46 files, 355 used, 7532 free (20 frags, 939 blocks, 0.3% fragmentation)
MARK FILE SYSTEM CLEAN? yes
***** FILE SYSTEM MARKED CLEAN *****
***** FILE SYSTEM WAS MODIFIED *****
atactl: wd2: Device not configured
Can't read atactrl wd2 identify: Undefined error: 0
Hit Ctrl+C in the next 5 seconds to prevent mcu start
RUNNING MCU
net.inet.icmp.rediraccept: 1 -> 0
net.inet6.icmp6.rediraccept: 1 -> 0
/dev/rmd0c: 1.0MB (2048 sectors) block size 4096, fragment size 512
        using 4 cylinder groups of 0.25MB, 64 blks, 96 inodes.
super-block backups (for fsck -b #) at:
   32,  544, 1056, 1568,
cfev: driver loaded successfully - built at Dec  7 2004 12:46:29
Module loaded as ID 0
stack at 0xffffdbd0
ftrace_inited = 0x2105f90
ftrace_init done
user mbuf init
sendbatch_init
ssl init
175047.843 SYSTEM : Info : Cisco TelePresence MCU 4505 4.3(2.32) (Build 6.18(2.32)) starting
175047.874 SYSTEM : Info : device configuration successfully loaded
175049.303 NETWORK : Info : SSL successfully initialised
175049.317 NETWORK : Info : DTLS successfully initialised
net.inet.tcp.keepidle: 14400 -> 120
net.inet.tcp.keepintvl: 150 -> 20
net.inet.tcp.keepcnt: 8 -> 4
175050.976 HEALTH_MONITOR : Info : Temperature 0 = 32.5
175050.981 HEALTH_MONITOR : Info : Temperature 1 = 33.0
175050.981 SYSTEM : Info : Disabling core dumps
175050.992 UPGRADE : Info : clearing local features cache
175051.046 CLUSTER : Info : feature disabled
175051.201 PIPELOG : Info : network control initialised
175051.212 NETWORK : Info : Initialising IP routes
175051.591 NETWORK : Info : activating ethernet Port A with auto-negotiation
175051.639 NETWORK : Info : activating ethernet Port A with auto-negotiation
175051.682 NETWORK : Info : deactivating port A IPv6
175051.682 NETWORK : Info : activating ethernet Port B with auto-negotiation
175051.998 NETWORK : Info : activating ethernet Port B with auto-negotiation
175052.039 NETWORK : Info : deactivating port B IPv6
175052.040 NETWORK : Info : activating ethernet Port A with auto-negotiation
175052.088 NETWORK : Info : activating port A IPv4 with fixed IP parameters
175052.088 NETWORK : Info : activating ethernet Port B with auto-negotiation
175052.169 NETWORK : Info : deactivating port B IPv4
175052.269 NETCONF : Info : Added route 0.0.0.0/0x0 192.168.1.1
175102.409 UPGRADE : Info : Hardware compatibility: 00000002 / 00000002
have video forward socket, port 65534
175102.698 USER_MANAGER : Info : 2 users present
175102.759 CUSTOMIZATION : Info : customisation configuration read; starting with 1-off 2-off
175102.770 CUSTOMIZATION : Info : Doing customisation resources init
175102.857 NETCONF : Info : media connect on bge0 (3)
175103.325 SYSTEM : Info : default text tokens loaded - 6706 tokens (UTF-8 format)
175103.330 RECORD_STORAGE : Info : record_storage module initialised
card ready
wd1: no disk label
175109.408 CDR : Info : CDR storage available
175109.409 CDR : Info : Finding archived sections
175109.459 CDR : Info : Finding current sections
shell initshell init175110.886 CDR : Info : Current sections OK
175110.887 SYSTEM : Info : Unique id initialised
175110.898 SHELL : Info : Serial shell unsecured
175110.898 SHELL : Info : Serial shell in recovery mode.
175111.309 CAPABILITIES : Info : Creating 162 capability sets
cfev opened by 0x1fb2338 (pid=62)
MCU:> 175111.504 AUDIT : Info : Audit storage available
175112.474 SYSTEM : Info : Unique id change thread starting
175113.004 SIP : Info : SIP initialised
175113.394 GATEKEEPER : Info : enabling built-in gatekeeper
175113.432 AUTO_ATTENDANT : Info : initialised - 1 present
175113.501 API : Info : initialised database
175113.919 AUDIT : Error : Audit log failed to shutdown correctly in previous boot, audits dropped.
175113.920 RECORD_STORAGE : Error : Record not in section
175113.920 AUDIT : Error : File read error while reading Audit hash file
175113.920 AUDIT : Info : Problem with primary hash file, trying to read backup hash file
175113.923 RECORD_STORAGE : Error : Record not in section
175113.923 AUDIT : Error : File read error while reading Audit hash file
175113.924 AUDIT : Warning : Problem with secondary hash file, no audit hashing data available.  Log may be compromised
175113.924 AUDIT : Warning : Audit hash files not found, rebuilding hashes. Ignore if first use.
175114.876 CONFERENCE : Info : initialising font support
dsp_init log version 1
user mbuf init
pci_init()
plx bar0=80a00000 bar2=80800000 bar3=80900000
MARBR=00200000
configure_fpga mezz_rp.bit
...................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................175132.529 SYSLOG : Info : sending from default port 514
bitstream load done
stat_paddr=00528000 (0xd5e26000) rx_used_ring_paddr=00538000 (0x538000)
rx poll start
fan status ok
configure_db_fpga2 db6455_setup_rp.bit 70000000
done
configure_db_fpga2 db6455_rp_2.bit 70000000
done
enabling mezz link port rx
sh[0]=02 sh[1]=01 sh[2]=01 sh[3]=01 num_slots=00000004
slot 0 height 0 set router id 00000000
slot 1 height 0 set router id 00000001
slot 2 height 0 set router id 00000002
slot 3 height 0 set router id 00000003
slot 0 height 0 pulse prog 0
slot 0 height 0 pulse prog 1
slot 0 height 0 set_link_enable
slot 0 height 1 set router id 00000004
DSP_TRACE(ff) : dsp : init done
opening DSP 00000000
DSP 00000000 handle 0x5eb4d20
opening DSP 00000001
DSP 00000001 handle 0x5eb4d80
opening DSP 00000002
DSP 00000002 handle 0x5eb4da0
opening DSP 00000003
DSP 00000003 handle 0x5eb4dc0
opening DSP 00000010
DSP 00000010 handle 0x5eb4de0
opening DSP 00000011
DSP 00000011 handle 0x5eb4e00
opening DSP 00000012
DSP 00000012 handle 0x5eb4e20
opening DSP 00000013
DSP 00000013 handle 0x5eb4e40
opening DSP 00000020
DSP 00000020 handle 0x5eb4e60
opening DSP 00000021
DSP 00000021 handle 0x5eb4e80
opening DSP 00000022
DSP 00000022 handle 0x5eb4ea0
opening DSP 00000023
DSP 00000023 handle 0x5eb4ec0
opening DSP 00000030
DSP 00000030 handle 0x5eb4ee0
opening DSP 00000031
DSP 00000031 handle 0x5eb4f00
opening DSP 00000032
DSP 00000032 handle 0x5eb4f20
opening DSP 00000033
DSP 00000033 handle 0x5eb4f40
opening DSP 00000100
DSP 00000100 handle 0x5eb4f60
opening DSP 00000101
DSP 00000101 handle 0x5eb4f80
opening DSP 00000102
DSP 00000102 handle 0x5eb4fa0
opening DSP 00000103
DSP 00000103 handle 0x5eb4fc0
opening DSP 00000110
DSP 00000110 handle 0x5eb4fe0
opening DSP 00000111
DSP 00000111 handle 0x4bea020
opening DSP 00000112
DSP 00000112 handle 0x4bea040
opening DSP 00000113
DSP 00000113 handle 0x4bea060
opening DSP 00000120
DSP 00000120 handle 0x4bea080
opening DSP 00000121
DSP 00000121 handle 0x4bea0a0
opening DSP 00000122
DSP 00000122 handle 0x4bea0c0
opening DSP 00000123
DSP 00000123 handle 0x4bea0e0
opening DSP 00000130
DSP 00000130 handle 0x4bea100
opening DSP 00000131
DSP 00000131 handle 0x4bea120
opening DSP 00000132
DSP 00000132 handle 0x4bea140
opening DSP 00000133
DSP 00000133 handle 0x4bea160
opening DSP 00000200
DSP 00000200 handle 0x4bea1a0
opening DSP 00000201
DSP 00000201 handle 0x4bea1c0
opening DSP 00000202
DSP 00000202 handle 0x4bea1e0
opening DSP 00000203
DSP 00000203 handle 0x4bea200
opening DSP 00000210
DSP 00000210 handle 0x4bea220
opening DSP 00000211
DSP 00000211 handle 0x4bea240
opening DSP 00000212
DSP 00000212 handle 0x4bea260
opening DSP 00000213
DSP 00000213 handle 0x4bea280
opening DSP 00000220
DSP 00000220 handle 0x4bea2a0
opening DSP 00000221
DSP 00000221 handle 0x4bea2c0
opening DSP 00000222
DSP 00000222 handle 0x4bea2e0
opening DSP 00000223
DSP 00000223 handle 0x4bea300
opening DSP 00000230
DSP 00000230 handle 0x4bea320
opening DSP 00000231
DSP 00000231 handle 0x4bea340
opening DSP 00000232
DSP 00000232 handle 0x4bea360
opening DSP 00000233
DSP 00000233 handle 0x4bea380
opening DSP 00000300
DSP 00000300 handle 0x4bea3a0
opening DSP 00000301
DSP 00000301 handle 0x4bea3c0
opening DSP 00000302
DSP 00000302 handle 0x4bea3e0
opening DSP 00000303
DSP 00000303 handle 0x4bea400
opening DSP 00000310
DSP 00000310 handle 0x4bea420
opening DSP 00000311
DSP 00000311 handle 0x4bea440
opening DSP 00000312
DSP 00000312 handle 0x4bea460
opening DSP 00000313
DSP 00000313 handle 0x4bea480
opening DSP 00000320
DSP 00000320 handle 0x4bea4a0
opening DSP 00000321
DSP 00000321 handle 0x4bea4c0
opening DSP 00000322
DSP 00000322 handle 0x4bea4e0
opening DSP 00000323
DSP 00000323 handle 0x4bea500
opening DSP 00000330
DSP 00000330 handle 0x4bea520
opening DSP 00000331
DSP 00000331 handle 0x4bea540
opening DSP 00000332
DSP 00000332 handle 0x4bea560
opening DSP 00000333
DSP 00000333 handle 0x4bea580
http_new_op_callback = 0x1804664
loading dsp image "mcudsp.out" on 00000000 0x5eb4d20
loading symtab
175327.020 SYSTEM : Info : mutex 0x34968D0 (&mps_connection_mutex) locked for 132.045s by /stripe/builduser/TXQBMIAG/art_release_6_18/shared/mp_streams/zaphod_mp_streams_msg.cpp:1070
175327.033 SYSTEM : Info : Unique id looking for file with name "/rdwr/persistent_id/conference_id.uid"
175327.037 SYSTEM : Info : Successfully opened file and read starting id as 648000
175327.102 SYSTEM : Info : mutex 0x36ACCE0 (&conference_manager_mutex) locked for 133.325s by /stripe/builduser/TXQBMIAG/art_release_6_18/mcu/conference_manager/conference_manager_api.cpp:1320
175327.269 NETWORK : Info : Registering tunnel prefix with http handler
175327.302 WEB_PAGES : Info : page services initialised
175327.626 SYSTEM : Info : Unique id "conference_id" was written; new allocation is 650000
175327.637 SIP : Info : Starting SIP TCP service
175327.638 SIP : Info : Starting SIPS TCP service
175327.638 SIP : Info : Starting SIP UDP service
175328.551 WEB_PAGES : Info : Regenerating help page index
175331.881 API : Info : shared components initialised
175331.883 API : Info : initialised
175331.934 CONFERENCE : Info : starting up scheduled conference "CONF1"
load done on 0x5eb4d20 856
hsi at 0090b544
loading dsp image "mcudsp.out" on 00000001 0x5eb4d80
loading symtab
DSP(00000000) : os_error:ring_handler stack: local 0x90F88C (0x11111111) ... global 0xE00CB560 (0x0)
DSP(00000000) : os_error:*** DSP_ID=0x0 booted (rev = 0x00010001)
DSP(00000000) : os_error:vs_thread stack: local 0x996424 (0x33333333) ... global 0xE003901C (0x0)
DSP(00000000) : os_error:as_thread stack: local 0x9983A4 (0x22222222) ... global 0xE00CCC58 (0x0)
reg done
DSP(00000000) : **** mpvs_ip_init returning
load done on 0x5eb4d80 144
hsi at 0090b544
loading dsp image "mcudsp.out" on 00000002 0x5eb4da0
loading symtab
DSP(00000001) : os_error:ring_handler stack: local 0x90F88C (0x11111111) ... global 0xE00CB560 (0x0)
DSP(00000001) : os_error:*** DSP_ID=0x1 booted (rev = 0x00010001)
DSP(00000001) : os_error:vs_thread stack: local 0x996424 (0x33333333) ... global 0xE003901C (0x0)
DSP(00000001) : os_error:as_thread stack: local 0x9983A4 (0x22222222) ... global 0xE00CCC58 (0x0)
reg done
sending dtod init complete to 00 (0x5eb4d20)
DSP(00000001) : **** mpvs_ip_init returning
175339.176 MEDIA_STREAMS : Info : all DSPs now initialised
175341.928 CONFERENCE : Info : audio resource 1 now available
175345.039 CONFERENCE : Info : video resource 1 now available
load done on 0x5eb4da0 659
hsi at 0090b544
loading dsp image "mcudsp.out" on 00000003 0x5eb4dc0
loading symtab
DSP(00000002) : os_error:ring_handler stack: local 0x90F88C (0x11111111) ... global 0xE00CB560 (0x0)
DSP(00000002) : os_error:*** DSP_ID=0x2 booted (rev = 0x00010001)
DSP(00000002) : os_error:vs_thread stack: local 0x996424 (0x33333333) ... global 0xE003901C (0x0)
DSP(00000002) : os_error:as_thread stack: local 0x9983A4 (0x22222222) ... global 0xE00CCC58 (0x0)
reg done
DSP(00000002) : **** mpvs_ip_init returning
175346.806 CONFERENCE : Info : video resource 2 now available
load done on 0x5eb4dc0 218
hsi at 0090b544
loading dsp image "mcudsp.out" on 00000100 0x5eb4f60
loading symtab
DSP(00000003) : os_error:ring_handler stack: local 0x90F88C (0x11111111) ... global 0xE00CB560 (0x0)
DSP(00000003) : os_error:*** DSP_ID=0x3 booted (rev = 0x00010001)
DSP(00000003) : os_error:vs_thread stack: local 0x996424 (0x33333333) ... global 0xE003901C (0x0)
DSP(00000003) : os_error:as_thread stack: local 0x9983A4 (0x22222222) ... global 0xE00CCC58 (0x0)
reg done
DSP(00000003) : **** mpvs_ip_init returning
175349.652 CONFERENCE : Info : video resource 3 now available
load done on 0x5eb4f60 196
hsi at 0090b544
loading dsp image "mcudsp.out" on 00000101 0x5eb4f80
loading symtab
DSP(00000100) : os_error:ring_handler stack: local 0x90F88C (0x11111111) ... global 0xE00CB560 (0x0)
DSP(00000100) : os_error:*** DSP_ID=0x100 booted (rev = 0x00010001)
DSP(00000100) : os_error:vs_thread stack: local 0x996424 (0x33333333) ... global 0xE003901C (0x0)
DSP(00000100) : os_error:as_thread stack: local 0x9983A4 (0x22222222) ... global 0xE00CCC58 (0x0)
reg done
DSP(00000100) : **** mpvs_ip_init returning
175351.710 CONFERENCE : Info : audio resource 2 now available
load done on 0x5eb4f80 161
hsi at 0090b544
loading dsp image "mcudsp.out" on 00000102 0x5eb4fa0
loading symtab
DSP(00000101) : os_error:ring_handler stack: local 0x90F88C (0x11111111) ... global 0xE00CB560 (0x0)
DSP(00000101) : os_error:*** DSP_ID=0x101 booted (rev = 0x00010001)
DSP(00000101) : os_error:vs_thread stack: local 0x996424 (0x33333333) ... global 0xE003901C (0x0)
DSP(00000101) : os_error:as_thread stack: local 0x9983A4 (0x22222222) ... global 0xE00CCC58 (0x0)
reg done
DSP(00000101) : **** mpvs_ip_init returning
175354.399 CONFERENCE : Info : video resource 4 now available
load done on 0x5eb4fa0 173
hsi at 0090b544
loading dsp image "mcudsp.out" on 00000103 0x5eb4fc0
loading symtab
DSP(00000102) : os_error:ring_handler stack: local 0x90F88C (0x11111111) ... global 0xE00CB560 (0x0)
DSP(00000102) : os_error:*** DSP_ID=0x102 booted (rev = 0x00010001)
DSP(00000102) : os_error:vs_thread stack: local 0x996424 (0x33333333) ... global 0xE003901C (0x0)
DSP(00000102) : os_error:as_thread stack: local 0x9983A4 (0x22222222) ... global 0xE00CCC58 (0x0)
reg done
DSP(00000102) : **** mpvs_ip_init returning
175356.962 CONFERENCE : Info : video resource 5 now available
load done on 0x5eb4fc0 211
hsi at 0090b544
loading dsp image "mcudsp.out" on 00000010 0x5eb4de0
loading symtab
DSP(00000103) : os_error:ring_handler stack: local 0x90F88C (0x11111111) ... global 0xE00CB560 (0x0)
DSP(00000103) : os_error:*** DSP_ID=0x103 booted (rev = 0x00010001)
DSP(00000103) : os_error:vs_thread stack: local 0x996424 (0x33333333) ... global 0xE003901C (0x0)
DSP(00000103) : os_error:as_thread stack: local 0x9983A4 (0x22222222) ... global 0xE00CCC58 (0x0)
reg done
DSP(00000103) : **** mpvs_ip_init returning
175359.617 CONFERENCE : Info : video resource 6 now available
EXIT 1
May 14 17:54:01 reboot: rebooted by root
syncing disks... done
rebooting
*** (C) Codian Ltd 2004-2005 ***
Resetting PCI
Calling Mpc107init
Mpc107init done
Testing SDRAM data lines ... ok
Testing SDRAM address lines ... ok
Relocating .text from FFF00000-FFF0B36E to 0E010000
Relocating .data from FFF0B380 to 0E01B380-0E01B7C8
Clearing .bss from 0E01B7C8-0E09EDA4
Initialising timebase regs
Calling mainL1 strap : built at Jul  7 2005 - 23:19:46
L2 found : image size 000362e4 version 2005:07:08 11:19
Starting L2
L2 Bootstrap
Relocating .text from FFF10000-FFF450B0 to 0E010000
Relocating .data from FFF450C0 to 0E0450C0-0E0462E4
Clearing .bss from 0E0462E4-0E0CA930
Calling mainHello from l2_main
card detected in internal slot (EXCA_STATUS = 4c)
waiting until status ready ...ok!
mounting dos0
fatsize = 00010000
card detected in external slot (EXCA_STATUS = 6f)
mounting dos1
fatsize = 0001f200
Product - Unknown (00000050)
MAC address - 00:0d:7c:00:69:86
Serial number - SM0034C3
Slotmask : 00000008
03 -
Devmode : 00000000
Trying dos0:netbsd
fd=7
loadelf line 78
loadelf line 86
loadelf line 93
loadelf line 150
loadelf line 165
loadelf line 178
loadelf line 200
loadelf line 200
ok
MARK[0] = 00090000
MARK[1] = 00090000
MARK[2] = 00000001
MARK[3] = 0044f8dc
MARK[4] = 00490444
ksyms_init
cpu0: HID0 90c000
eumbbus_submatch
sc_ioh=fc004500
com0: console
00011120
eumbbus_submatch
sc_ioh=fc004600
00011140
about to setup pci
line=0xff
line=0x00
line=0x01
line=0x0c
line=0x0f
line=0x0f
configure_bus 0
configure_bridge 1
configure_bus 1
configure_bridge 2
configure_bus 2
pci_mem_find
pci_mem_find
pci1 at ppb0 bus 1
pci2 at ppb1 bus 2
res=80000000
sock_base=80000000
pci_mem_find
res=80001000
sock_base=80001000
pci_mem_find
000103e0
000103e0
mainbus attach done
kthread_create
ccdattach
i2c_attach
board_init
pcmcia card attach
card ready
card ready
memory mapped mode
pcmcia card attach
card ready
card ready
memory mapped mode
card ready
wd1: no disk label
card ready
card ready
card ready
card ready
rtcinit()
Warm Boot
Time is now 17:54:52.51 14/05/13
May 14 17:54:55 init: /etc/pwd.db: No such file or directory
** /dev/rwd0b
** /dev/rwd0d
** File system is clean; not checking
RUNNING MCU
stack at 0xffffdbd0
ftrace_init done
user mbuf init
sendbatch_init
ssl init
175515.444 SYSTEM : Info : Cisco TelePresence MCU 4505 4.3(2.32) (Build 6.18(2.32)) starting
175515.475 SYSTEM : Info : device configuration successfully loaded
175516.868 NETWORK : Info : SSL successfully initialised
175516.882 NETWORK : Info : DTLS successfully initialised
175518.538 HEALTH_MONITOR : Info : Temperature 0 = 32.5
175518.543 HEALTH_MONITOR : Info : Temperature 1 = 33.0
175518.544 SYSTEM : Info : Disabling core dumps
175518.555 UPGRADE : Info : clearing local features cache
175518.608 CLUSTER : Info : feature disabled
175518.763 PIPELOG : Info : network control initialised
175518.774 NETWORK : Info : Initialising IP routes
175519.116 NETWORK : Info : activating ethernet Port A with auto-negotiation
175519.171 NETWORK : Info : activating ethernet Port A with auto-negotiation
175519.519 NETWORK : Info : deactivating port A IPv6
175519.519 NETWORK : Info : activating ethernet Port B with auto-negotiation
175519.566 NETWORK : Info : activating ethernet Port B with auto-negotiation
175519.607 NETWORK : Info : deactivating port B IPv6
175519.608 NETWORK : Info : activating ethernet Port A with auto-negotiation
175519.656 NETWORK : Info : activating port A IPv4 with fixed IP parameters
175519.656 NETWORK : Info : activating ethernet Port B with auto-negotiation
175519.698 NETWORK : Info : deactivating port B IPv4
175519.826 NETCONF : Info : Added route 0.0.0.0/0x0 192.168.1.1
175529.987 UPGRADE : Info : Hardware compatibility: 00000002 / 00000002
175530.275 USER_MANAGER : Info : 2 users present
175530.336 CUSTOMIZATION : Info : customisation configuration read; starting with 1-off 2-off
175530.347 CUSTOMIZATION : Info : Doing customisation resources init
175530.462 NETCONF : Info : media connect on bge0 (3)
175530.799 SYSTEM : Info : default text tokens loaded - 6706 tokens (UTF-8 format)
175530.804 RECORD_STORAGE : Info : record_storage module initialised
card ready
wd1: no disk label
175536.904 CDR : Info : CDR storage available
175536.904 CDR : Info : Finding archived sections
175536.956 CDR : Info : Finding current sections
175538.384 CDR :c Info : Current fsections OK
shell initshell init175538.387 SYSTEM : Info : Unique id initialised
175538.417 SHELL : Info : Serial shell unsecured
175538.418 SHELL : Info : Serial shell in recovery mode.
175538.830 CAPABILITIES : Info : Creating 162 capability sets
175539.024 SYSTEM : Info : Unique id change thread starting
175539.024 AUDIT : Info : Audit storage available
175539.644 SIP : Info : SIP initialised
175539.858 GATEKEEPER : Info : enabling built-in gatekeeper
175539.896 AUTO_ATTENDANT : Info : initialised - 1 present
175539.975 API : Info : initialised database
MCU:> dsp_init log version 1
user mbuf init
pci_init()
MARBR=00200000
175541.613 CONFERENCE : Info : initialising font support
175542.613 AUDIT : Error : Audit log failed to shutdown correctly in previous boot, audits dropped.
175542.623 AUDIT : Info : Reading hashes of audit log
175542.623 AUDIT : Info : Calculating file hashes and checking against read hash
175542.623 AUDIT : Info : Completed Audit hash check
....................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................175600.111 SYSLOG : Info : sending from default port 514
bitstream load done
rx poll start
fan status ok
done
done
DSP 00000000 handle 0x5ea7d80
DSP 00000001 handle 0x5ea7de0
DSP 00000002 handle 0x5ea7e00
DSP 00000003 handle 0x5ea7e20
DSP 00000010 handle 0x5ea7e40
DSP 00000011 handle 0x5ea7e60
DSP 00000012 handle 0x5ea7e80
DSP 00000013 handle 0x5ea7ea0
DSP 00000020 handle 0x5ea7ec0
DSP 00000021 handle 0x5ea7ee0
DSP 00000022 handle 0x5ea7f00
DSP 00000023 handle 0x5ea7f20
DSP 00000030 handle 0x5ea7f40
DSP 00000031 handle 0x5ea7f60
DSP 00000032 handle 0x5ea7f80
DSP 00000033 handle 0x5ea7fa0
DSP 00000100 handle 0x5ea7fc0
DSP 00000101 handle 0x5ea7fe0
DSP 00000102 handle 0x4488020
DSP 00000103 handle 0x4488040
DSP 00000110 handle 0x4488060
DSP 00000111 handle 0x4488080
DSP 00000112 handle 0x44880a0
DSP 00000113 handle 0x44880c0
DSP 00000120 handle 0x44880e0
DSP 00000121 handle 0x4488100
DSP 00000122 handle 0x4488120
DSP 00000123 handle 0x4488140
DSP 00000130 handle 0x4488160
DSP 00000131 handle 0x4488180
DSP 00000132 handle 0x44881a0
DSP 00000133 handle 0x44881c0
DSP 00000200 handle 0x4488200
DSP 00000201 handle 0x4488220
DSP 00000202 handle 0x4488240
DSP 00000203 handle 0x4488260
DSP 00000210 handle 0x4488280
DSP 00000211 handle 0x44882a0
DSP 00000212 handle 0x44882c0
DSP 00000213 handle 0x44882e0
DSP 00000220 handle 0x4488300
DSP 00000221 handle 0x4488320
DSP 00000222 handle 0x4488340
DSP 00000223 handle 0x4488360
DSP 00000230 handle 0x4488380
DSP 00000231 handle 0x44883a0
DSP 00000232 handle 0x44883c0
DSP 00000233 handle 0x44883e0
DSP 00000300 handle 0x4488400
DSP 00000301 handle 0x4488420
DSP 00000302 handle 0x4488440
DSP 00000303 handle 0x4488460
DSP 00000310 handle 0x4488480
DSP 00000311 handle 0x44884a0
DSP 00000312 handle 0x44884c0
DSP 00000313 handle 0x44884e0
DSP 00000320 handle 0x4488500
DSP 00000321 handle 0x4488520
DSP 00000322 handle 0x4488540
DSP 00000323 handle 0x4488560
DSP 00000330 handle 0x4488580
DSP 00000331 handle 0x44885a0
DSP 00000332 handle 0x44885c0
DSP 00000333 handle 0x44885e0
loading dsp image "mcudsp.out" on 00000000 0x5ea7d80
loading symtab
175754.084 SYSTEM : Info : mutex 0x34968D0 (&mps_connection_mutex) locked for 132.439s by /stripe/builduser/TXQBMIAG/art_release_6_18/shared/mp_streams/zaphod_mp_streams_msg.cpp:1070
175754.098 SYSTEM : Info : Unique id looking for file with name "/rdwr/persistent_id/conference_id.uid"
175754.101 SYSTEM : Info : Successfully opened file and read starting id as 650000
175754.167 SYSTEM : Info : mutex 0x36ACCE0 (&conference_manager_mutex) locked for 134.167s by /stripe/builduser/TXQBMIAG/art_release_6_18/mcu/conference_manager/conference_manager_api.cpp:1320
175754.333 NETWORK : Info : Registering tunnel prefix with http handler
175754.366 WEB_PAGES : Info : page services initialised
175754.878 SIP : Info : Starting SIP TCP service
175754.878 SIP : Info : Starting SIPS TCP service
175754.879 SIP : Info : Starting SIP UDP service
175754.953 SYSTEM : Info : Unique id "conference_id" was written; new allocation is 652000
175755.198 WEB_PAGES : Info : Regenerating help page index
175757.841 API : Info : shared components initialised
175757.976 API : Info : initialised
175758.028 CONFERENCE : Info : starting up scheduled conference "CONF1"
load done on 0x5ea7d80 838
hsi at 0090b544
loading dsp image "mcudsp.out" on 00000001 0x5ea7de0
loading symtab
reg done
load done on 0x5ea7de0 157
hsi at 0090b544
loading dsp image "mcudsp.out" on 00000002 0x5ea7e00
loading symtab
reg done
sending dtod init complete to 00 (0x5ea7d80)
175806.164 MEDIA_STREAMS : Info : all DSPs now initialised
175808.409 CONFERENCE : Info : audio resource 1 now available
175812.010 CONFERENCE : Info : video resource 1 now available
load done on 0x5ea7e00 667
hsi at 0090b544
loading dsp image "mcudsp.out" on 00000003 0x5ea7e20
loading symtab
reg done
175814.001 CONFERENCE : Info : video resource 2 now available
load done on 0x5ea7e20 176
hsi at 0090b544
loading dsp image "mcudsp.out" on 00000100 0x5ea7fc0
loading symtab
reg done
175817.068 CONFERENCE : Info : video resource 3 now available
load done on 0x5ea7fc0 186
hsi at 0090b544
loading dsp image "mcudsp.out" on 00000101 0x5ea7fe0
loading symtab
reg done
175818.799 CONFERENCE : Info : audio resource 2 now available
175819.460 WEB_PAGES : Info : starting new session
175819.460 WEB_PAGES : Info : new administrator login for "admin" from 192.168.1.3
load done on 0x5ea7fe0 203
hsi at 0090b544
loading dsp image "mcudsp.out" on 00000102 0x4488020
loading symtab
reg done
175821.976 CONFERENCE : Info : video resource 4 now available
load done on 0x4488020 192
hsi at 0090b544
loading dsp image "mcudsp.out" on 00000103 0x4488040
loading symtab
reg done
175824.374 CONFERENCE : Info : video resource 5 now available
load done on 0x4488040 192
hsi at 0090b544
loading dsp image "mcudsp.out" on 00000010 0x5ea7e40
loading symtab
reg done
175827.213 CONFERENCE : Info : video resource 6 now available
EXIT 1
May 14 17:58:29 reboot: rebooted by root
rebooting
Resetting PCI
Calling Mpc107init
Mpc107init done
Starting L2
L2 Bootstrap
mounting dos0
fatsize = 00010000
mounting dos1
fatsize = 0001f200
Slotmask : 00000008
03 -
Devmode : 00000000
Trying dos0:netbsd
fd=7
loadelf line 78
loadelf line 86
loadelf line 93
loadelf line 150
loadelf line 165
loadelf line 178
loadelf line 200
loadelf line 200
ok
MARK[0] = 00090000
MARK[1] = 00090000
MARK[2] = 00000001
MARK[3] = 0044f8dc
MARK[4] = 00490444
ksyms_init
cpu0: HID0 90c000
eumbbus_submatch
sc_ioh=fc004500
com0: console
00011120
eumbbus_submatch
sc_ioh=fc004600
00011140
about to setup pci
line=0xff
line=0x00
line=0x01
line=0x0c
line=0x0f
line=0x0f
configure_bus 0
configure_bridge 1
configure_bus 1
configure_bridge 2
configure_bus 2
pci_mem_find
pci_mem_find
pci1 at ppb0 bus 1
pci2 at ppb1 bus 2
res=80000000
sock_base=80000000
pci_mem_find
res=80001000
sock_base=80001000
pci_mem_find
000103e0
000103e0
mainbus attach done
kthread_create
ccdattach
i2c_attach
board_init
pcmcia card attach
card ready
card ready
memory mapped mode
pcmcia card attach
card ready
card ready
memory mapped mode
card ready
wd1: no disk label
card ready
card ready
card ready
card ready
rtcinit()
Warm Boot
Time is now 17:59:19.64 14/05/13
May 14 17:59:22 init: /etc/pwd.db: No such file or directory
** /dev/rwd0b
** /dev/rwd0d
Nikhil
Looks like the flash card in the external slot of the system is having corrupted file , as suggested by patrick , please follow the kupgrade procedure. If you feel it ias cumbersome, better to raise a TAC case if under contract .
Sundar
Hi Sunder,
I tried upgrade through external Flash disk through kupgrade procedure, but still it is continiouslly rebotting. one more thing there were some files in the external flash diskwhich we removed from flash disk before upgrading & once the upgrade was done through kupgrade file we copied those files on flash disk.
Could this restart be because of those files in the flash disk.
Thanks in advance
Nikhil
Hi Nikhil
Was the output attached earlier is after kupgrade procedure . if not ,can you attach the logs again after kupgrade.
Sundar
hi Sunder,
Im attaching the output after upgrade below, kindly suggest what could be wrong here because of which MCU is rebooting continouesly as we could not seea any hardware issue with the mcu here :
Resetting PCI
Calling Mpc107init
Mpc107init done
Calling main
Starting L2
L2 Bootstrap
Calling main
Hello from l2_main
mounting dos0
fatsize = 00010000
mounting dos1
fatsize = 0007bc00
Motherboard serial number - ÿÿÿÿÿÿÿÿ
Slotmask : 00000008
03 - ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
Devmode : 00000000
copying dos1:kupgrade to md0:00000000...................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................0222ea40 bytes copied
Image version : 4.4(3.49)
fd=7
loadelf line 78
loadelf line 86
loadelf line 93
loadelf line 150
loadelf line 165
loadelf line 178
loadelf line 200
loadelf line 200
ok
MARK[0] = 00090000
MARK[1] = 00090000
MARK[2] = 00000001
MARK[3] = 022b9574
MARK[4] = 022edba8
calling ksyms_init (startkernel=0x090000 endkernel=0x22f8000 edata=0x0 end=0x7f454c46 startsym=0x22b9574 endsym=0x22edba8
ksyms_init
Loaded initial symtab at 0x22b9574, strtab at 0x22d5838, # entries 6714
NetBSD 1.6ZG (RAMDISK) #11: Wed Sep 17 11:52:59 BST 2008
simonr@penfold:/home/simonr/sw/netbsd/src/sys.clean/arch/marvin/compile/obj/RAMDISK
avail memory = 185 MB
cpu0: HID0 90c000
eumbbus_submatch
bus_space_map(00280210, fc004500, 00000008..)
sc_ioh=fc004500
com_attach_subr iot=00280210 ioh=fc004500 type=00000000 freq=06baa800
com0: console
00011120
eumbbus_submatch
bus_space_map(00280210, fc000000, 00000008..)
sc_ioh=fc004600
com_attach_subr iot=00280210 ioh=fc004600 type=00000000 freq=06baa800
00011140
about to setup pci
line=0xff
line=0x00
line=0x01
line=0x0c
line=0x0f
line=0x0f
configure_bus 0
configure_bridge 1
configure_bus 1
configure_bridge 2
configure_bus 2
pci_mapreg_map 00000010 type 4 tag=0xd006f234 h=0xd006f230
pci_mem_find
pci_mapreg_map 00000010 type 4 tag=0xd0073234 h=0xd0073230
pci_mem_find
pci1 at ppb0 bus 1
pci2 at ppb1 bus 2
pa_iot=00280100 pa_memt=00280210 pa_flags=00000003 pa_bus=00000002 pa_device=00000000
base=80000000 offs=00000000 limit=fe000000 extent=0x22adaf0
res=80000000
sock_base=80000000
pci_mapreg_map 00000010 type 0 tag=0xd0060a48 h=0xd0060a4c
pci_mem_find
pa_iot=00280100 pa_memt=00280210 pa_flags=00000003 pa_bus=00000002 pa_device=00000001
res=80001000
sock_base=80001000
pci_mapreg_map 00000010 type 0 tag=0xd0060848 h=0xd006084c
pci_mem_find
000103e0
000103e0
mainbus attach done
kthread_create
md0: internal 32768 KB image area
board_init
pcmcia card attach
card ready
card ready
memory mapped mode
pcmcia card attach
card ready
card ready
memory mapped mode
root on md0a dumps on md0b
rtcinit()
Cold Boot - power down at 13:50:41.00 16/05/13
Time is now 13:56:01.97 16/05/13
codian: kupgrade
card ready
card ready
/dev/wd0d: file system not clean (fs_clean=4); please fsck(8)
/dev/wd0d: lost blocks 0 files 0
mkdir: /cflash/rdwr/dev: File exists
Extracting read-write fs
  0%      0       0.00 KB/s    --:-- ETA
100%  10240      24.13 KB/s    00:00 ETA
/dev/rwd0a: 64.0MB (131072 sectors) block size 8192, fragment size 1024
        using 4 cylinder groups of 16.00MB, 2048 blks, 3968 inodes.
    32, 32800, 65568, 98336,
Extracting root fs
  0%  32768      30.61 KB/s    28:18 ETA
  0%  49152      23.91 KB/s    36:14 ETA
  0%    480 KB  157.31 KB/s    05:27 ETA
  2%   1232 KB  304.94 KB/s    02:46 ETA
  3%   2064 KB  407.66 KB/s    02:02 ETA
  5%   2783 KB  463.39 KB/s    01:46 ETA
  5%   3008 KB  427.23 KB/s    01:54 ETA
  6%   3424 KB  427.87 KB/s    01:53 ETA
  7%   3728 KB  411.39 KB/s    01:57 ETA
  8%   4240 KB  423.58 KB/s    01:52 ETA
  9%   4931 KB  447.07 KB/s    01:45 ETA
11%   5763 KB  478.55 KB/s    01:36 ETA
12%   6595 KB  507.20 KB/s    01:29 ETA
14%   7496 KB  533.19 KB/s    01:23 ETA
15%   8259 KB  550.26 KB/s    01:19 ETA
17%   9091 KB  566.91 KB/s    01:15 ETA
18%   9842 KB  578.87 KB/s    01:12 ETA
20%  10691 KB  592.56 KB/s    01:09 ETA
22%  11523 KB  604.51 KB/s    01:07 ETA
23%  12291 KB  614.04 KB/s    01:04 ETA
25%  13120 KB  623.21 KB/s    01:02 ETA
26%  13891 KB  630.89 KB/s    01:00 ETA
28%  14787 KB  641.12 KB/s    00:58 ETA
29%  15583 KB  649.25 KB/s    00:56 ETA
31%  16387 KB  655.37 KB/s    00:54 ETA
33%  17280 KB  663.00 KB/s    00:52 ETA
34%  18115 KB  669.53 KB/s    00:50 ETA
36%  18930 KB  675.07 KB/s    00:49 ETA
37%  19698 KB  678.71 KB/s    00:47 ETA
39%  20502 KB  683.37 KB/s    00:46 ETA
41%  21375 KB  689.35 KB/s    00:44 ETA
42%  22211 KB  693.15 KB/s    00:43 ETA
44%  23040 KB  697.31 KB/s    00:41 ETA
45%  23814 KB  699.66 KB/s    00:40 ETA
47%  24611 KB  703.11 KB/s    00:39 ETA
48%  25408 KB  705.39 KB/s    00:37 ETA
50%  26271 KB  709.90 KB/s    00:36 ETA
52%  27120 KB  713.20 KB/s    00:34 ETA
53%  27968 KB  716.91 KB/s    00:33 ETA
55%  28673 KB  716.38 KB/s    00:32 ETA
56%  29360 KB  715.10 KB/s    00:31 ETA
57%  30144 KB  717.64 KB/s    00:30 ETA
59%  30960 KB  719.13 KB/s    00:29 ETA
61%  31809 KB  722.01 KB/s    00:28 ETA
62%  32509 KB  721.41 KB/s    00:27 ETA
63%  33260 KB  722.61 KB/s    00:26 ETA
66%  34365 KB  730.97 KB/s    00:24 ETA
67%  35072 KB  730.59 KB/s    00:23 ETA
69%  36000 KB  734.66 KB/s    00:21 ETA
70%  36949 KB  738.64 KB/s    00:20 ETA
71%  37397 KB  732.31 KB/s    00:20 ETA
72%  37821 KB  727.26 KB/s    00:19 ETA
73%  38304 KB  722.03 KB/s    00:19 ETA
74%  38608 KB  714.74 KB/s    00:18 ETA
75%  39297 KB  714.19 KB/s    00:17 ETA
76%  40000 KB  713.88 KB/s    00:16 ETA
78%  40656 KB  712.76 KB/s    00:15 ETA
79%  41136 KB  709.17 KB/s    00:15 ETA
79%  41617 KB  704.31 KB/s    00:14 ETA
79%  41633 KB  692.37 KB/s    00:15 ETA
81%  42225 KB  691.65 KB/s    00:14 ETA
82%  42768 KB  689.30 KB/s    00:13 ETA
82%  43167 KB  685.15 KB/s    00:12 ETA
84%  43821 KB  684.44 KB/s    00:12 ETA
85%  44561 KB  685.18 KB/s    00:10 ETA
86%  45231 KB  684.88 KB/s    00:09 ETA
88%  45935 KB  685.19 KB/s    00:08 ETA
89%  46415 KB  682.12 KB/s    00:08 ETA
89%  46431 KB  672.83 KB/s    00:08 ETA
89%  46431 KB  663.14 KB/s    00:08 ETA
90%  47103 KB  662.91 KB/s    00:07 ETA
91%  47631 KB  660.38 KB/s    00:06 ETA
91%  47695 KB  652.99 KB/s    00:06 ETA
91%  47775 KB  643.96 KB/s    00:06 ETA
91%  47839 KB  636.41 KB/s    00:06 ETA
92%  47887 KB  629.75 KB/s    00:06 ETA
92%  47951 KB  622.17 KB/s    00:06 ETA
92%  48015 KB  614.30 KB/s    00:06 ETA
92%  48095 KB  607.69 KB/s    00:06 ETA
94%  49343 KB  616.17 KB/s    00:04 ETA
96%  49983 KB  616.81 KB/s    00:03 ETA
97%  50687 KB  617.81 KB/s    00:02 ETA
98%  51279 KB  617.58 KB/s    00:01 ETA
99%  51871 KB  617.28 KB/s    00:00 ETA
99%  51887 KB  610.37 KB/s    00:00 ETA
99%  51903 KB  603.19 KB/s    00:00 ETA
99%  51919 KB  596.34 KB/s    00:00 ETA
99%  51919 KB  589.92 KB/s    00:00 ETA
99%  51935 KB  583.23 KB/s    00:00 ETA
99%  51951 KB  577.14 KB/s    00:00 ETA
99%  51967 KB  571.02 KB/s    00:00 ETA
99%  51967 KB  564.46 KB/s    00:00 ETA
99%  51983 KB  558.75 KB/s    00:00 ETA
99%  51999 KB  553.00 KB/s    00:00 ETA
99%  51999 KB  547.23 KB/s    00:00 ETA
99%  52015 KB  541.44 KB/s    00:00 ETA
99%  52015 KB  535.87 KB/s    00:00 ETA
99%  52015 KB  530.73 KB/s    00:00 ETA
99%  52031 KB  525.15 KB/s    00:00 ETA
99%  52031 KB  520.13 KB/s    00:00 ETA
99%  52047 KB  515.23 KB/s    00:00 ETA
100%  52050 KB  510.22 KB/s    00:00 ETA
100%  52050 KB  505.58 KB/s    00:00 ETA
Installing etc
cp: symlink: /sbin/nologin: File exists
Installing kernel
umount: /cflash/root: Device busy
rm: /cflash/fat/netbsd~*: No such file or directory
rm: /cflash/fat/kupgrade: No such file or directory
May 16 13:58:09 reboot: rebooted by rootsyncing disks... done
rebooting
Resetting PCI
Calling Mpc107init
Mpc107init done
Calling main
Starting L2
L2 Bootstrap
Calling main
Hello from l2_main
mounting dos0
fatsize = 00010000
mounting dos1
fatsize = 0007bc00
Slotmask : 00000008
Devmode : 00000000
fd=7
loadelf line 78
loadelf line 86
loadelf line 93
loadelf line 150
loadelf line 165
loadelf line 178
loadelf line 200
loadelf line 200
ok
MARK[0] = 00090000
MARK[1] = 00090000
MARK[2] = 00000001
MARK[3] = 022b9574
MARK[4] = 022edba8
ksyms_init
cpu0: HID0 90c000
eumbbus_submatch
sc_ioh=fc004500
com0: console
00011120
eumbbus_submatch
sc_ioh=fc004600
00011140
about to setup pci
line=0xff
line=0x00
line=0x01
line=0x0c
line=0x0f
line=0x0f
configure_bus 0
configure_bridge 1
configure_bus 1
configure_bridge 2
configure_bus 2
pci_mem_find
pci_mem_find
pci1 at ppb0 bus 1
pci2 at ppb1 bus 2
res=80000000
sock_base=80000000
pci_mem_find
res=80001000
sock_base=80001000
pci_mem_find
000103e0
000103e0
mainbus attach done
kthread_create
board_init
pcmcia card attach
card ready
card ready
memory mapped mode
pcmcia card attach
card ready
card ready
memory mapped mode
rtcinit()
Warm Boot
Time is now 13:59:57.30 16/05/13
codian: kupgrade
card ready
card ready
/dev/wd0d: file system not clean (fs_clean=8); please fsck(8)
100%  10240      21.43 KB/s    00:00 ETA
Extracting root fs
  0%  32768      30.73 KB/s    28:12 ETA
  0%  49152      23.53 KB/s    36:49 ETA
  1%    544 KB  178.88 KB/s    04:47 ETA
  2%   1343 KB  335.26 KB/s    02:31 ETA
  4%   2128 KB  424.14 KB/s    01:57 ETA
  5%   2864 KB  474.93 KB/s    01:43 ETA
  5%   3008 KB  429.25 KB/s    01:54 ETA^[[C^[[D^[[C
  7%   3664 KB  455.12 KB/s    01:46 ETA
  7%   3920 KB  430.86 KB/s    01:51 ETA
  8%   4447 KB  444.54 KB/s    01:47 ETA
10%   5251 KB  476.08 KB/s    01:38 ETA
11%   5955 KB  494.74 KB/s    01:33 ETA
13%   6787 KB  521.86 KB/s    01:26 ETA
14%   7683 KB  546.85 KB/s    01:21 ETA
16%   8479 KB  565.16 KB/s    01:17 ETA
17%   9266 KB  578.65 KB/s    01:13 ETA
19%  10098 KB  592.57 KB/s    01:10 ETA
20%  10893 KB  605.03 KB/s    01:08 ETA
22%  11725 KB  614.29 KB/s    01:05 ETA
24%  12493 KB  623.10 KB/s    01:03 ETA
25%  13261 KB  631.43 KB/s    01:01 ETA
27%  14130 KB  641.42 KB/s    00:59 ETA
28%  14979 KB  650.01 KB/s    00:57 ETA
30%  15795 KB  658.09 KB/s    00:55 ETA
31%  16643 KB  664.14 KB/s    00:53 ETA
33%  17458 KB  670.10 KB/s    00:51 ETA
35%  18303 KB  677.85 KB/s    00:49 ETA
36%  19104 KB  682.26 KB/s    00:48 ETA
38%  19890 KB  684.72 KB/s    00:46 ETA
39%  20675 KB  688.94 KB/s    00:45 ETA
41%  21568 KB  694.84 KB/s    00:43 ETA
43%  22403 KB  699.95 KB/s    00:42 ETA
44%  23235 KB  703.54 KB/s    00:40 ETA
46%  24050 KB  706.09 KB/s    00:39 ETA
47%  24835 KB  708.97 KB/s    00:38 ETA
49%  25650 KB  711.74 KB/s    00:37 ETA
50%  26499 KB  715.88 KB/s    00:35 ETA
52%  27393 KB  719.94 KB/s    00:34 ETA
53%  28097 KB  720.01 KB/s    00:33 ETA
55%  28848 KB  720.37 KB/s    00:32 ETA
57%  29695 KB  724.21 KB/s    00:30 ETA
58%  30448 KB  724.26 KB/s    00:29 ETA
60%  31295 KB  727.72 KB/s    00:28 ETA
61%  32065 KB  728.35 KB/s    00:27 ETA
63%  32799 KB  728.79 KB/s    00:26 ETA
64%  33580 KB  729.71 KB/s    00:25 ETA
66%  34673 KB  737.01 KB/s    00:23 ETA
68%  35521 KB  739.36 KB/s    00:22 ETA
69%  36388 KB  742.14 KB/s    00:21 ETA
71%  37069 KB  741.35 KB/s    00:20 ETA
72%  37680 KB  738.26 KB/s    00:19 ETA
73%  38112 KB  731.74 KB/s    00:19 ETA
74%  38528 KB  726.55 KB/s    00:18 ETA
75%  39072 KB  723.54 KB/s    00:17 ETA
76%  39793 KB  722.79 KB/s    00:16 ETA
77%  40514 KB  722.31 KB/s    00:15 ETA
78%  40934 KB  717.94 KB/s    00:15 ETA
79%  41448 KB  714.54 KB/s    00:14 ETA
79%  41633 KB  705.03 KB/s    00:14 ETA
80%  41969 KB  699.38 KB/s    00:14 ETA
81%  42630 KB  698.64 KB/s    00:13 ETA
82%  43120 KB  695.05 KB/s    00:12 ETA
84%  43821 KB  694.90 KB/s    00:11 ETA
85%  44373 KB  693.24 KB/s    00:11 ETA
86%  44974 KB  690.82 KB/s    00:10 ETA
87%  45615 KB  691.09 KB/s    00:09 ETA
89%  46415 KB  691.46 KB/s    00:08 ETA
89%  46415 KB  682.34 KB/s    00:08 ETA
89%  46431 KB  672.67 KB/s    00:08 ETA
89%  46431 KB  661.48 KB/s    00:08 ETA
89%  46527 KB  653.05 KB/s    00:08 ETA
89%  46591 KB  645.26 KB/s    00:08 ETA
89%  46655 KB  637.24 KB/s    00:08 ETA
89%  46719 KB  630.87 KB/s    00:08 ETA
89%  46783 KB  622.17 KB/s    00:08 ETA
90%  46863 KB  615.33 KB/s    00:08 ETA
90%  46943 KB  608.93 KB/s    00:08 ETA
91%  47679 KB  611.15 KB/s    00:07 ETA
94%  49231 KB  622.92 KB/s    00:04 ETA
95%  49903 KB  623.61 KB/s    00:03 ETA
97%  50495 KB  622.95 KB/s    00:02 ETA
98%  51151 KB  623.71 KB/s    00:01 ETA
99%  51716 KB  622.95 KB/s    00:00 ETA
99%  51892 KB  617.70 KB/s    00:00 ETA
99%  51892 KB  610.34 KB/s    00:00 ETA
99%  51908 KB  603.19 KB/s    00:00 ETA
99%  51924 KB  596.78 KB/s    00:00 ETA
99%  51924 KB  590.03 KB/s    00:00 ETA
99%  51940 KB  583.30 KB/s    00:00 ETA
99%  51956 KB  577.27 KB/s    00:00 ETA
99%  51972 KB  570.99 KB/s    00:00 ETA
99%  51972 KB  564.76 KB/s    00:00 ETA
99%  51988 KB  558.77 KB/s    00:00 ETA
99%  51988 KB  552.84 KB/s    00:00 ETA
99%  52004 KB  547.29 KB/s    00:00 ETA
99%  52004 KB  541.66 KB/s    00:00 ETA
99%  52020 KB  536.09 KB/s    00:00 ETA
99%  52020 KB  530.60 KB/s    00:00 ETA
99%  52036 KB  525.48 KB/s    00:00 ETA
99%  52036 KB  520.24 KB/s    00:00 ETA
100%  52050 KB  515.25 KB/s    00:00 ETA^[[C
100%  52050 KB  510.23 KB/s    00:00 ETA
100%  52050 KB  508.81 KB/s    00:00 ETA
Installing etc
Installing kernel
May 16 14:02:04 reboot: rebooted by rootsyncing disks... done
rebooting
Resetting PCI
Calling Mpc107init
Mpc107init done
Calling main
Starting L2
L2 Bootstrap
Calling main
Hello from l2_main
mounting dos0
fatsize = 00010000
no card in external slot (EXCA_A[EXCA_STATUS] = 04)
Slotmask : 00000008
Devmode : 00000000
Resetting PCI
Calling Mpc107init
Mpc107init done
Calling main
Starting L2
L2 Bootstrap
Calling main
Hello from l2_main
mounting dos0
fatsize = 00010000
Slotmask : 00000008
Devmode : 00000000
Trying dos0:netbsd
copying dos0:netbsd to md0:00000000............................................002beb9a bytes copied
fd=6
loadelf fd=6 Elf_Ehdr=0xefffe58 marks=0xe0c632c flags=0000003f
loadelf line 78
loadelf line 86
loadelf line 93
loadelf line 150
loadelf line 165
loadelf line 178
loadelf line 200
loadelf line 200
ok
MARK[0] = 00090000
MARK[1] = 00090000
MARK[2] = 00000001
MARK[3] = 0044fb8c
MARK[4] = 00490740
calling ksyms_init (startkernel=0x090000 endkernel=0x49b000 edata=0x0 end=0x7f454c46 startsym=0x44fb8c endsym=0x490740
ksyms_init
Loaded initial symtab at 0x44fb8c, strtab at 0x472060, # entries 8180
NetBSD 1.6ZG (LANGLEY) #ZJITC_N_1_48: Mon Jun 25 17:53:16 BST 2012
TANDBERG@BUILDMACHINE:LANGLEY
cpu0: HID0 90c000
eumbbus_submatch
bus_space_map(0030119c, fc004500, 00000008..)
sc_ioh=fc004500
com_attach_subr iot=0030119c ioh=fc004500 type=00000000 freq=06baa800
com0: console
00011120
eumbbus_submatch
bus_space_map(0030119c, fc000000, 00000008..)
sc_ioh=fc004600
com_attach_subr iot=0030119c ioh=fc004600 type=00000000 freq=06baa800
00011140
about to setup pci
line=0xff
line=0x00
line=0x01
line=0x0c
line=0x0f
line=0x0f
configure_bus 0
configure_bridge 1
configure_bus 1
configure_bridge 2
configure_bus 2
pci_mem_find
pci_mem_find
pci1 at ppb0 bus 1
pci2 at ppb1 bus 2
pa_iot=0030108c pa_memt=0030119c pa_flags=00000003 pa_bus=00000002 pa_device=00000000
base=80000000 offs=00000000 limit=fe000000 extent=0x331700
res=80000000
sock_base=80000000
pci_mem_find
pa_iot=0030108c pa_memt=0030119c pa_flags=00000003 pa_bus=00000002 pa_device=00000001
res=80001000
sock_base=80001000
pci_mem_find
000103e0
000103e0
mainbus attach done
kthread_create
ccdattach
i2c_attach
board_init
pcmcia card attach
card ready
card ready
memory mapped mode
card ready
card ready
card ready
card ready
rtcinit()
Watchdog tripped at 14:02:27.00 16/05/13
Cold Boot - power down at 14:02:27.00 16/05/13
Time is now 14:03:06.99 16/05/13
May 16 14:03:10 init: /etc/pwd.db: No such file or directoryfsck: Cannot open `/etc/fstab': No such file or directory
** /dev/rwd0b
19 files, 62524 free (31262 clusters)
** /dev/rwd0d
** Last Mounted on /cflash/rdwr
51 files, 353 used, 7534 free (14 frags, 940 blocks, 0.2% fragmentation)
RUNNING MCU
stack at 0xffffdbc0
ftrace_inited = 0x211ca48
ftrace_init done
user mbuf init
sendbatch_init
140330.299 SYSTEM : Info : Cisco TelePresence MCU 4505 4.4(3.49) (Build 6.18(3.49)) starting
140330.486 SYSTEM : Info : device configuration successfully loaded
ssl init
140334.034 HEALTH_MONITOR : Info : Temperature 0 = 35.0
140334.039 HEALTH_MONITOR : Info : Temperature 1 = 35.0
140334.040 SYSTEM : Info : Disabling core dumps
140334.061 UPGRADE : Info : clearing local features cache
140334.112 CLUSTER : Info : feature enabled
140334.241 PIPELOG : Info : network control initialised
140334.262 NETWORK : Info : Initialising IP routes
140334.323 NETWORK : Info : Failed to read network services configuration; assuming default settings
140334.415 NETWORK : Info : Failed to read network services configuration; assuming default settings
140334.421 NETWORK : Info : Failed to read network services configuration; assuming default settings
140334.643 NETWORK : Info : activating ethernet Port A with auto-negotiation
140334.685 NETWORK : Info : activating ethernet Port A with auto-negotiation
140334.723 NETWORK : Info : deactivating port A IPv6
140334.727 NETWORK : Info : activating ethernet Port B with auto-negotiation
140334.774 NETWORK : Info : activating ethernet Port B with auto-negotiation
140334.815 NETWORK : Info : deactivating port B IPv6
140334.815 NETWORK : Info : activating ethernet Port A with auto-negotiation
140334.863 NETWORK : Info : activating port A IPv4 with fixed IP parameters
140334.864 NETWORK : Info : activating ethernet Port B with auto-negotiation
140334.905 NETWORK : Info : deactivating port B IPv4
140335.033 NETCONF : Info : Added route 0.0.0.0/0x0 192.168.1.1
140345.088 UPGRADE : Info : Hardware compatibility: 00000002 / 00000002
140345.721 USER_MANAGER : Info : 2 users present
140345.752 CUSTOMIZATION : Info : customisation configuration read; starting with 1-off 2-off
140345.763 CUSTOMIZATION : Info : Doing customisation resources init
140346.598 SYSTEM : Info : default text tokens loaded - 6889 tokens (UTF-8 format)
140346.603 RECORD_STORAGE : Info : record_storage module initialised
cfev opened by 0x206f1a0 (pid=60)
shell initshell init140401.823 SYSTEM : Info : Unique id initialised
140401.824 SHELL : Info : Serial shell unsecured
140401.825 SHELL : Info : Serial shell in recovery mode.
140401.995 CAPABILITIES : Info : Creating 162 capability sets
140402.081 SYSTEM : Info : Unique id change thread starting
MCU:> 140402.604 SIP : Info : SIP initialised
140403.067 AUTO_ATTENDANT : Info : initialised - 1 present
140403.138 API : Info : initialised database
140403.773 CONFERENCE : Info : initialising font support
user mbuf init
pci_init()
MARBR=00200000
.....................................................................................................................................................................................................................................................................................................................140415.320 SYSLOG : Info : sending IPv4 from default port
140415.320 SYSLOG : Info : sending IPv6 from default port
bitstream load done
rx poll start
fan status ok
done
done
DSP 00000000 handle 0x6b8d060
DSP 00000001 handle 0x6b8d0a0
DSP 00000002 handle 0x6b8d0c0
DSP 00000003 handle 0x6b8d0e0
DSP 00000010 handle 0x6b8d100
DSP 00000011 handle 0x6b8d120
DSP 00000012 handle 0x6b8d140
DSP 00000013 handle 0x6b8d160
DSP 00000020 handle 0x6b8d180
DSP 00000021 handle 0x6b8d1a0
DSP 00000022 handle 0x6b8d1c0
DSP 00000023 handle 0x6b8d1e0
DSP 00000030 handle 0x6b8d200
DSP 00000031 handle 0x6b8d220
DSP 00000032 handle 0x6b8d240
DSP 00000033 handle 0x6b8d260
DSP 00000100 handle 0x6b8d280
DSP 00000101 handle 0x6b8d2a0
DSP 00000102 handle 0x6b8d2c0
DSP 00000103 handle 0x6b8d2e0
DSP 00000110 handle 0x6b8d300
DSP 00000111 handle 0x6b8d320
DSP 00000112 handle 0x6b8d340
DSP 00000113 handle 0x6b8d380
DSP 00000120 handle 0x6b8d3a0
DSP 00000121 handle 0x6b8d3c0
DSP 00000122 handle 0x6b8d3e0
DSP 00000123 handle 0x6b8d400
DSP 00000130 handle 0x6b8d420
DSP 00000131 handle 0x6b8d440
DSP 00000132 handle 0x6b8d460
DSP 00000133 handle 0x6b8d480
DSP 00000200 handle 0x6b8d4a0
DSP 00000201 handle 0x6b8d4c0
DSP 00000202 handle 0x6b8d4e0
DSP 00000203 handle 0x6b8d500
DSP 00000210 handle 0x6b8d520
DSP 00000211 handle 0x6b8d540
DSP 00000212 handle 0x6b8d560
DSP 00000213 handle 0x6b8d580
DSP 00000220 handle 0x6b8d5a0
DSP 00000221 handle 0x6b8d5c0
DSP 00000222 handle 0x6b8d5e0
DSP 00000223 handle 0x6b8d600
DSP 00000230 handle 0x6b8d620
DSP 00000231 handle 0x6b8d640
DSP 00000232 handle 0x6b8d660
DSP 00000233 handle 0x6b8d680
DSP 00000300 handle 0x6b8d6a0
DSP 00000301 handle 0x6b8d6c0
DSP 00000302 handle 0x6b8d6e0
DSP 00000303 handle 0x6b8d700
DSP 00000310 handle 0x6b8d720
DSP 00000311 handle 0x6b8d740
DSP 00000312 handle 0x6b8d760
DSP 00000313 handle 0x6b8d7a0
DSP 00000320 handle 0x6b8d7c0
DSP 00000321 handle 0x6b8d7e0
DSP 00000322 handle 0x6b8d800
DSP 00000323 handle 0x6b8d820
DSP 00000330 handle 0x6b8d840
DSP 00000331 handle 0x6b8d860
DSP 00000332 handle 0x6b8d880
DSP 00000333 handle 0x6b8d8a0
loading dsp image "mcudsp.out" on 00000000 0x6b8d060
loading symtab
140615.346 SYSTEM : Info : mutex 0x3408AB4 (&mps_connection_mutex) locked for 131.426s by /stripe/builduser/CAAGDKRF/mcu_release_6_18_3/shared/mp_streams/zaphod_mp_streams_msg.cpp:1070
140615.399 SYSTEM : Info : Unique id looking for file with name "/rdwr/persistent_id/conference_id.uid"
140615.403 SYSTEM : Info : Successfully opened file and read starting id as 760000
140615.897 SYSTEM : Info : Unique id "conference_id" was written; new allocation is 762000
140617.858 SYSTEM : Info : mutex 0x3620BE8 (&conference_manager_mutex) locked for 134.712s by /stripe/builduser/CAAGDKRF/mcu_release_6_18_3/mcu/conference_manager/conference_manager_api.cpp:1396
http_new_op_callback = 0x180466c
140618.459 SIP : Info : Starting SIP TCP service
140618.460 SIP : Info : Starting SIPS TCP service
140618.460 SIP : Info : Starting SIP UDP service
140618.472 NETWORK : Info : Registering tunnel prefix with http handler
140618.571 WEB_PAGES : Info : page services initialised
140619.718 WEB_PAGES : Info : Regenerating help page index
140623.674 API : Info : shared components initialised
140623.675 API : Info : initialised
load done on 0x6b8d060 862
hsi at 0090b544
loading dsp image "mcudsp.out" on 00000001 0x6b8d0a0
loading symtab
reg done
load done on 0x6b8d0a0 154
hsi at 0090b544
loading dsp image "mcudsp.out" on 00000002 0x6b8d0c0
loading symtab
reg done
sending dtod init complete to 00 (0x6b8d060)
140627.363 MEDIA_STREAMS : Info : all DSPs now initialised
140629.508 CONFERENCE : Info : audio resource 1 now available
load done on 0x6b8d0c0 659
140633.328 CONFERENCE : Info : video resource 1 now available
hsi at 0090b544
loading dsp image "mcudsp.out" on 00000003 0x6b8d0e0
loading symtab
reg done
140635.034 CONFERENCE : Info : video resource 2 now available
load done on 0x6b8d0e0 206
hsi at 0090b544
loading dsp image "mcudsp.out" on 00000100 0x6b8d280
loading symtab
reg done
140637.721 CONFERENCE : Info : video resource 3 now available
load done on 0x6b8d280 195
hsi at 0090b544
loading dsp image "mcudsp.out" on 00000101 0x6b8d2a0
loading symtab
reg done
140639.767 CONFERENCE : Info : audio resource 2 now available
load done on 0x6b8d2a0 147
hsi at 0090b544
loading dsp image "mcudsp.out" on 00000102 0x6b8d2c0
loading symtab
reg done
140642.651 CONFERENCE : Info : video resource 4 now available
load done on 0x6b8d2c0 186
hsi at 0090b544
loading dsp image "mcudsp.out" on 00000103 0x6b8d2e0
loading symtab
reg done
140645.057 CONFERENCE : Info : video resource 5 now available
load done on 0x6b8d2e0 191
hsi at 0090b544
loading dsp image "mcudsp.out" on 00000010 0x6b8d100
loading symtab
reg done
140648.024 CONFERENCE : Info : video resource 6 now available
dsp_write_buf timeout
EXIT 1
May 16 14:06:49 reboot: rebooted by rootsyncing disks... done
rebooting
Resetting PCI
Calling Mpc107init
Mpc107init done
Calling main
Starting L2
L2 Bootstrap
Calling main
Hello from l2_main
mounting dos0
fatsize = 00010000
Slotmask : 00000008
Devmode : 00000000
Trying dos1:kupgrade
error opening source file dos1:kupgrade
Trying dos0:kupgrade
error opening source file dos0:kupgrade
Trying dos0:netbsd
Image version : netbsd_home:/bin/netbsd-ramdisk-32M
fd=6
loadelf line 78
loadelf line 86
loadelf line 93
loadelf line 150
loadelf line 165
loadelf line 178
loadelf line 200
loadelf line 200
ok
MARK[0] = 00090000
MARK[1] = 00090000
MARK[2] = 00000001
MARK[3] = 0044fb8c
MARK[4] = 00490740
ksyms_init
Copyright (c) 1996, 1997, 1998, 1999, 2000, 2001, 2002, 2003
    The NetBSD Foundation, Inc.  All rights reserved.
Copyright (c) 1982, 1986, 1989, 1991, 1993
    The Regents of the University of California.  All rights reserved.
total memory = 240 MB
avail memory = 215 MB
using 3072 buffers containing 12388 KB of memory
sysctl_createv: sysctl_create(cacheinfo) returned 17
mainbus0 (root)mainbus_attach
eumbbus_match: cpu eumbbus
cpu0 at mainbus0: Version 0x8081 (Revision 0x1014), ID 0 (primary)
cpu0: HID0 90c000
config_found cpu done
eumbbus_match: eumbbus eumbbus
eumbbus0 at mainbus0eumbbus_attach
eumbbus_submatch
com0 at eumbbus0com_eumbbus_attach
sc_ioh=fc004500
com0: console
00011120
eumbbus_submatch
sc_ioh=fc004600
00011140
about to setup pci
line=0xff
line=0x00
line=0x01
line=0x0c
line=0x0f
line=0x0f
configure_bus 0
configure_bridge 1
configure_bus 1
configure_bridge 2
configure_bus 2
pci_mem_find
pci_mem_find
pci1 at ppb0 bus 1
pci2 at ppb1 bus 2
res=80000000
sock_base=80000000
pci_mem_find
res=80001000
sock_base=80001000
pci_mem_find
000103e0
000103e0
mainbus attach done
kthread_create
*** dll_stat_reg=90f000c1
ccdattach
i2c_attach
board_init
pcmcia card attach
card ready
card ready
memory mapped mode
card ready
card ready
card ready
card ready
rtcinit()
Warm Boot
Time is now 14:07:32.12 16/05/13
May 16 14:07:35 init: /etc/pwd.db: No such file or directoryfsck: Cannot open `/etc/fstab': No such file or directory
** /dev/rwd0b
** /dev/rwd0d
RUNNING MCU
stack at 0xffffdbc0
ftrace_init done
user mbuf init
sendbatch_init
140754.950 SYSTEM : Info : Cisco TelePresence MCU 4505 4.4(3.49) (Build 6.18(3.49)) starting
140755.126 SYSTEM : Info : device configuration successfully loaded
ssl init
140758.675 HEALTH_MONITOR : Info : Temperature 0 = 35.0
140758.680 HEALTH_MONITOR : Info : Temperature 1 = 36.0
140758.680 SYSTEM : Info : Disabling core dumps
140758.701 UPGRADE : Info : clearing local features cache
140758.754 CLUSTER : Info : feature enabled
140758.883 PIPELOG : Info : network control initialised
140758.904 NETWORK : Info : Initialising IP routes
140758.964 NETWORK : Info : Failed to read network services configuration; assuming default settings
140759.054 NETWORK : Info : Failed to read network services configuration; assuming default settings
140759.060 NETWORK : Info : Failed to read network services configuration; assuming default settings
140759.281 NETWORK : Info : activating ethernet Port A with auto-negotiation
140759.323 NETWORK : Info : activating ethernet Port A with auto-negotiation
140759.363 NETWORK : Info : deactivating port A IPv6
140759.365 NETWORK : Info : activating ethernet Port B with auto-negotiation
140759.413 NETWORK : Info : activating ethernet Port B with auto-negotiation
140759.454 NETWORK : Info : deactivating port B IPv6
140759.455 NETWORK : Info : activating ethernet Port A with auto-negotiation
140759.503 NETWORK : Info : activating port A IPv4 with fixed IP parameters
140759.504 NETWORK : Info : activating ethernet Port B with auto-negotiation
140759.544 NETWORK : Info : deactivating port B IPv4
140759.671 NETCONF : Info : Added route 0.0.0.0/0x0 192.168.1.1
140809.726 UPGRADE : Info : Hardware compatibility: 00000002 / 00000002
140810.383 USER_MANAGER : Info : 2 users present
140810.414 CUSTOMIZATION : Info : customisation configuration read; starting with 1-off 2-off
140810.425 CUSTOMIZATION : Info : Doing customisation resources init
140811.268 SYSTEM : Info : default text tokens loaded - 6889 tokens (UTF-8 format)
140811.273 RECORD_STORAGE : Info : record_storage module initialised
shell initshell init140826.485 SYSTEM : Info : Unique id initialised
140826.486 SHELL : Info : Serial shell unsecured
140826.487 SHELL : Info : Serial shell in recovery mode.
140826.614 SYSTEM : Info : Unique id change thread starting
MCU:> 140826.701 CAPABILITIES : Info : Creating 162 capability sets
140827.254 SIP : Info : SIP initialised
140827.721 AUTO_ATTENDANT : Info : initialised - 1 present
140827.792 API : Info : initialised database
user mbuf init
140828.435 CONFERENCE : Info : initialising font support
pci_init()
MARBR=00200000
.................................................................................................................................................................................................................................................................................................................140839.881 SYSLOG : Info : sending IPv4 from default port
140839.881 SYSLOG : Info : sending IPv6 from default port
bitstream load done
rx poll start
fan status ok
done
done
loading symtab
141039.998 SYSTEM : Info : mutex 0x3408AB4 (&mps_connection_mutex) locked for 131.417s by /stripe/builduser/CAAGDKRF/mcu_release_6_18_3/shared/mp_streams/zaphod_mp_streams_msg.cpp:1070
141040.052 SYSTEM : Info : Unique id looking for file with name "/rdwr/persistent_id/conference_id.uid"
141040.055 SYSTEM : Info : Successfully opened file and read starting id as 762000
141040.521 SYSTEM : Info : Unique id "conference_id" was written; new allocation is 764000
141042.510 SYSTEM : Info : mutex 0x3620BE8 (&conference_manager_mutex) locked for 134.711s by /stripe/builduser/CAAGDKRF/mcu_release_6_18_3/mcu/conference_manager/conference_manager_api.cpp:1396
141043.034 SIP : Info : Starting SIP TCP service
141043.035 SIP : Info : Starting SIPS TCP service
141043.035 SIP : Info : Starting SIP UDP service
141043.122 NETWORK : Info : Registering tunnel prefix with http handler
141043.133 WEB_PAGES : Info : page services initialised
141043.508 WEB_PAGES : Info : Regenerating help page index
141047.705 API : Info : shared components initialised
141047.706 API : Info : initialised
load done on 0x6b8d060 847
hsi at 0090b544
loading symtab
reg done
load done on 0x6b8d0a0 145
hsi at 0090b544
loading symtab
reg done
141052.001 MEDIA_STREAMS : Info : all DSPs now initialised
141053.861 CONFERENCE : Info : audio resource 1 now available
load done on 0x6b8d0c0 633
141058.004 CONFERENCE : Info : video resource 1 now available
hsi at 0090b544
loading symtab
reg done
141059.851 CONFERENCE : Info : video resource 2 now available
load done on 0x6b8d0e0 186
hsi at 0090b544
loading symtab
reg done
141101.927 CONFERENCE : Info : video resource 3 now available
load done on 0x6b8d280 180
hsi at 0090b544
loading symtab
reg done
141104.267 CONFERENCE : Info : audio resource 2 now available
load done on 0x6b8d2a0 153
hsi at 0090b544
loading symtab
reg done
141106.938 CONFERENCE : Info : video resource 4 now available
load done on 0x6b8d2c0 177
hsi at 0090b544
loading symtab
reg done
141109.737 CONFERENCE : Info : video resource 5 now available
load done on 0x6b8d2e0 172
hsi at 0090b544
loading symtab
reg done
141112.129 CONFERENCE : Info : video resource 6 now available
EXIT 1
May 16 14:11:14 reboot: rebooted by rootsyncing disks... done
rebooting
Resetting PCI
Calling Mpc107init
Mpc107init done
Calling main
Starting L2
L2 Bootstrap
Calling main
Hello from l2_main
mounting dos0
fatsize = 00010000
no card in external slot (EXCA_A[EXCA_STATUS] = 00)
Slotmask : 00000008
Devmode : 00000000
Trying dos0:netbsd
fd=6
loadelf line 78
loadelf line 86
loadelf line 93
loadelf line 150
loadelf line 165
loadelf line 178
loadelf line 200
loadelf line 200
ok
MARK[0] = 00090000
MARK[1] = 00090000
MARK[2] = 00000001
MARK[3] = 0044fb8c
MARK[4] = 00490740
ksyms_init
cpu0: HID0 90c000
eumbbus_submatch
sc_ioh=fc004500
: ns16550a, working fifo
com0: console
intr_establish 00000014
00011120
eumbbus_submatch
com1 at eumbbus0com_eumbbus_attach
sc_ioh=fc004600
intr_establish 00000015
00011140
about to setup pci
calling pci configurepci_conf_interrupt bus 0x00000000 dev 0x00000000
line=0xff
pci_conf_interrupt bus 0x00000000 dev 0x00000010
line=0x00
pci_conf_interrupt bus 0x00000000 dev 0x00000011
line=0x01
pci_conf_interrupt bus 0x00000001 dev 0x00000003
line=0x0c
pci_conf_interrupt bus 0x00000002 dev 0x00000000
line=0x0f
line=0x0f
configure_bus 0
configure_bridge 1
Bus 1 mem_base=80000000 mem_limit=80ffffff
configure_bus 1
configure_bridge 2
Bus 2 mem_base=80000000 mem_limit=807fffff
configure_bus 2
eumbbus_match: pci eumbbus
pci0 at mainbus0 bus 0
pci0: i/o space, memory space enabled
aceride_match 00061057
vendor 0x1057 product 0x0006 (host bridge, revision 0x14) at pci0 dev 0 function 0 not configured
aceride_match 165314e4
bge0 at pci0 dev 16 function 0: Broadcom BCM5705M Gigabit Ethernet
pci_mapreg_map 00000010 type 4 tag=0xd006b2b4 h=0xd006b2b0
pci_mem_find
bge0: ASIC BCM5705 A3, Ethernet address 00:0d:7c:00:69:86
brgphy0 at bge0 phy 1: BCM5705 1000BASE-T media interface, rev. 2
brgphy0: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseT, 1000baseT-FDX, auto
bge1 at pci0 dev 17 function 0: Broadcom BCM5705M Gigabit Ethernet
pci_mapreg_map 00000010 type 4 tag=0xd006f2b4 h=0xd006f2b0
pci_mem_find
bge1: ASIC BCM5705 A3, Ethernet address 00:0d:7c:00:69:87
brgphy1 at bge1 phy 1: BCM5705 1000BASE-T media interface, rev. 2
brgphy1: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseT, 1000baseT-FDX, auto
aceride_match ac28104c
ppb0 at pci0 dev 20 function 0: vendor 0x104c product 0xac28 (rev. 0x02)
pci1 at ppb0 bus 1
pci1: i/o space, memory space enabled
aceride_match 905610b5
vendor 0x10b5 product 0x9056 (miscellaneous bridge, revision 0xba) at pci1 dev 3 function 0 not configured
ppb1 at pci1 dev 6 function 0: vendor 0x104c product 0xac28 (rev. 0x02)
pci2 at ppb1 bus 2
pci2: i/o space, memory space enabled
aceride_match ac55104c
cbb1 at pci2 dev 0 function 0: vendor 0x104c product 0xac55 (rev. 0x01)
rbus_new_body: [2000, 2800] type dedicated name [rbus root]
extent `iomem' (0x80000000 - 0xfdffffff), flags = 0x3
res=80000000
rbus_new_body: [80004000, 80008000] type dedicated name [rbus root]
sock_base=80000000
pci_mapreg_map 00000010 type 0 tag=0xd005ca48 h=0xd005ca4c
pci_mem_find
cbb0 at pci2 dev 0 function 1: vendor 0x104c product 0xac55 (rev. 0x01)
rbus_new_body: [2800, 3000] type dedicated name [rbus root]
res=80001000
rbus_new_body: [80009000, 8000d000] type dedicated name [rbus root]
sock_base=80001000
pci_mapreg_map 00000010 type 0 tag=0xd005c848 h=0xd005c84c
pci_mem_find
pci_intr_map pin=0x03 line=0x0f
intr_establish 0000000f
000103e0
cbb1: interrupting at irq 15
cardslot1 at cbb1 slot 1 flags 0
cardslot1 attaching CardBus bus...
cardbus1 at cardslot1: bus 3 device 0
cardslotattach: found cardbus on cardslot1
pcmcia1 at cardslot1
cardslotattach: found 16-bit pcmcia bus
000103e0
cbb0: interrupting at irq 15
cardslot0 at cbb0 slot 0 flags 0
cardslot0 attaching CardBus bus...
cardbus0 at cardslot0: bus 4 device 0
cardslotattach: found cardbus on cardslot0
pcmcia0 at cardslot0
cardbusattach: 16-bit card found
cardslot_event_throw: an event 16-bit Card inserted comes
mainbus attach done
kthread_create
biomask 8000 netmask 8000 ttymask 8000
*** dll_stat_reg=91f000c1
ccdattach
Kernelized RAIDframe activated
i2c_attach
demux_table=0xf100000:0xf23ffff(00140000)
mbtrace=0xf200000:0xf5fffff(00400000)
board_init
pcmcia card attach
card ready
rbus_space_alloc: addr 0, size 1000, mask fff, align 1000
pcmcia0: CIS version PCMCIA 2.0 or 2.1
pcmcia0: CIS info: SILICONSYSTEMS, VER2.00
pcmcia0: Manufacturer code 0x0, product 0x0
pcmcia0: function 0: fixed disk(ata), ccr addr 200 mask f
pcmcia0: function 0, config table entry 0: memory card; irq mask 0; memspace 0-7ff; maxtwins 1; mwait_required rdybsy_active powerdown
pcmcia0: function 0, config table entry 1: I/O card; irq mask ffff; iomask 4, iospace 0-f; memspace 0-7ff; maxtwins 1; rdybsy_active io8 io16 irqshare irqpulse irqlevel powerdown
pcmcia0: function 0, config table entry 2: I/O card; irq mask 4000; iomask a, iospace 1f0-1f7 3f6-3f7; memspace 0-7ff; maxtwins 1; rdybsy_active io8 io16 irqshare irqpulse irqlevel powerdown
pcmcia0: function 0, config table entry 3: I/O card; irq mask 4000; iomask a, iospace 170-177 376-377; memspace 0-7ff; maxtwins 1; rdybsy_active io8 io16 irqshare irqpulse irqlevel powerdown
pcmcia0: function 0, config table entry 7: I/O card; irq mask 4000; iomask a, iospace 170-177 376-377; memspace 0-7ff; maxtwins 1; rdybsy_active io8 io16 irqshare irqpulse irqlevel powerdown
wdc0 at pcmcia0 function 0function type 00000000
card ready
memory mapped mode
wdc pcmcia memmode, noirq
atabus0 at wdc0 channel 0
wd0 at atabus0 drive 0:
wd0: drive supports 1-sector PIO transfers, LBA addressing
wd0: 248 MB, 994 cyl, 16 head, 32 sec, 512 bytes/sect x 508928 sectors
card ready
howto 2 bootdev 0 boot device: wd0
root on wd0a dumps on wd0b
card ready
about to call domountroothook
about to call vfs_mountroot
card ready
card ready
rtcinit()
Warm Boot
Time is now 14:11:56.65 16/05/13
root file system type: ffs
May 16 14:11:59 init: /etc/pwd.db: No such file or directoryfsck: Cannot open `/etc/fstab': No such file or directory
** /dev/rwd0b
** Phase 1 - Read and Compare FATs
** Phase 2 - Check Cluster Chains
** Phase 3 - Checking Directories
** Phase 4 - Checking for Lost Files
** /dev/rwd0d
atactl: wd2: Device not configured
Can't read atactrl wd2 identify: Undefined error: 0
Hit Ctrl+C in the next 5 seconds to prevent mcu start
RUNNING MCU
net.inet.icmp.rediraccept: 1 -> 0
net.inet6.icmp6.rediraccept: 1 -> 0
/dev/rmd0c: 1.0MB (2048 sectors) block size 4096, fragment size 512
        using 4 cylinder groups of 0.25MB, 64 blks, 96 inodes.
super-block backups (for fsck -b #) at:
   32,  544, 1056, 1568,
cfev: driver loaded successfully - built at Dec  7 2004 12:46:29
Module loaded as ID 0
stack at 0xffffdbc0
ftrace_init done
user mbuf init
sendbatch_init
141218.924 SYSTEM : Info : Cisco TelePresence MCU 4505 4.4(3.49) (Build 6.18(3.49)) starting
141219.101 SYSTEM : Info : device configuration successfully loaded
ssl init
net.inet.tcp.keepidle: 14400 -> 120
net.inet.tcp.keepintvl: 150 -> 20
net.inet.tcp.keepcnt: 8 -> 4
141222.647 HEALTH_MONITOR : Info : Temperature 0 = 35.5
141222.652 HEALTH_MONITOR : Info : Temperature 1 = 36.0
141222.653 SYSTEM : Info : Disabling core dumps
141222.674 UPGRADE : Info : clearing local features cache
141222.725 CLUSTER : Info : feature enabled
141222.854 PIPELOG : Info : network control initialised
141222.875 NETWORK : Info : Initialising IP routes
141222.936 NETWORK : Info : Failed to read network services configuration; assuming default settings
141223.050 NETWORK : Info : Failed to read network services configuration; assuming default settings
141223.056 NETWORK : Info : Failed to read network services configuration; assuming default settings
141223.324 NETWORK : Info : activating ethernet Port A with auto-negotiation
141223.367 NETWORK : Info : activating ethernet Port A with auto-negotiation
141223.407 NETWORK : Info : deactivating port A IPv6
141223.409 NETWORK : Info : activating ethernet Port B with auto-negotiation
141223.456 NETWORK : Info : activating ethernet Port B with auto-negotiation
141223.497 NETWORK : Info : deactivating port B IPv6
141223.498 NETWORK : Info : activating ethernet Port A with auto-negotiation
141223.546 NETWORK : Info : activating port A IPv4 with fixed IP parameters
141223.547 NETWORK : Info : activating ethernet Port B with auto-negotiation
141223.588 NETWORK : Info : deactivating port B IPv4
141223.717 NETCONF : Info : Added route 0.0.0.0/0x0 192.168.1.1
141233.771 UPGRADE : Info : Hardware compatibility: 00000002 / 00000002
have video forward socket, port 65534
141234.450 USER_MANAGER : Info : 2 users present
141234.480 CUSTOMIZATION : Info : customisation configuration read; starting with 1-off 2-off
141234.491 CUSTOMIZATION : Info : Doing customisation resources init
141235.134 SYSTEM : Info : default text tokens loaded - 6889 tokens (UTF-8 format)
141235.138 RECORD_STORAGE : Info : record_storage module initialised
shell initshell init141250.361 SYSTEM : Info : Unique id initialised
141250.362 SHELL : Info : Serial shell unsecured
141250.363 SHELL : Info : Serial shell in recovery mode.
141250.532 CAPABILITIES : Info : Creating 162 capability sets
141250.567 SYSTEM : Info : Unique id change thread starting
MCU:> 141251.137 SIP : Info : SIP initialised
141251.601 AUTO_ATTENDANT : Info : initialised - 1 present
141251.672 API : Info : initialised database
user mbuf init
141252.309 CONFERENCE : Info : initialising font support
pci_init()
plx bar0=80a00000 bar2=80800000 bar3=80900000
MARBR=00200000
configure_fpga mezz_rp.bit
...........................................................................................................................................................................................................................................................................................................................141303.943 SYSLOG : Info : sending IPv4 from default port
141303.943 SYSLOG : Info : sending IPv6 from default port
bitstream load done
stat_paddr=00528000 (0xd5e26000) rx_used_ring_paddr=00538000 (0x538000)
rx poll start
fan status ok
configure_db_fpga2 db6455_setup_rp.bit 70000000
done
Resetting PCI
Calling Mpc107init
Mpc107init done
Calling main
Starting L2
L2 Bootstrap
Calling main
Hello from l2_main
mounting dos0
fatsize = 00010000
mounting dos1
fatsize = 0007bc00
Slotmask : 00000008
Devmode : 00000000
fd=7
loadelf fd=7 Elf_Ehdr=0xefffe58 marks=0xe0c632c flags=0000003f
loadelf line 78
loadelf line 86
loadelf line 93
loadelf line 150
loadelf line 165
loadelf line 178
loadelf line 200
loadelf line 200
ok
MARK[0] = 00090000
MARK[1] = 00090000
MARK[2] = 00000001
MARK[3] = 022b9574
MARK[4] = 022edba8
ksyms_init
cpu0: HID0 90c000
eumbbus_submatch
sc_ioh=fc004500
com0: console
00011120
eumbbus_submatch
sc_ioh=fc004600
00011140
about to setup pci
line=0xff
line=0x00
line=0x01
line=0x0c
line=0x0f
line=0x0f
configure_bus 0
configure_bridge 1
configure_bus 1
configure_bridge 2
configure_bus 2
pci_mem_find
pci_mem_find
pci1 at ppb0 bus 1
pci2 at ppb1 bus 2
res=80000000
sock_base=80000000
pci_mem_find
res=80001000
sock_base=80001000
pci_mem_find
000103e0
000103e0
mainbus attach done
kthread_create
board_init
pcmcia card attach
card ready
pcmcia1: CIS version PCMCIA 2.0 or 2.1
pcmcia1: CIS info: SILICONSYSTEMS, VER2.00
pcmcia1: Manufacturer code 0x0, product 0x0
pcmcia1: function 0: fixed disk(ata), ccr addr 200 mask f
pcmcia1: function 0, config table entry 0: memory card; irq mask 0; memspace 0-7ff; maxtwins 1; mwait_required rdybsy_active powerdown
pcmcia1: function 0, config table entry 1: I/O card; irq mask ffff; iomask 4, iospace 0-f; memspace 0-7ff; maxtwins 1; rdybsy_active io8 io16 irqshare irqpulse irqlevel powerdown
pcmcia1: function 0, config table entry 2: I/O card; irq mask 4000; iomask a, iospace 1f0-1f7 3f6-3f7; memspace 0-7ff; maxtwins 1; rdybsy_active io8 io16 irqshare irqpulse irqlevel powerdown
pcmcia1: function 0, config table entry 3: I/O card; irq mask 4000; iomask a, iospace 170-177 376-377; memspace 0-7ff; maxtwins 1; rdybsy_active io8 io16 irqshare irqpulse irqlevel powerdown
pcmcia1: function 0, config table entry 7: I/O card; irq mask 4000; iomask a, iospace 170-177 376-377; memspace 0-7ff; maxtwins 1; rdybsy_active io8 io16 irqshare irqpulse irqlevel powerdown
wdc1 at pcmcia1 function 0function type 00000000
card ready
memory mapped mode
atabus1 at wdc1 channel 0
pcmcia card attach
card ready
card ready
memory mapped mode
wd1 at atabus1 drive 0:
wd1: drive supports 1-sector PIO transfers, LBA addressing
wd1: 248 MB, 994 cyl, 16 head, 32 sec, 512 bytes/sect x 508928 sectors
rtcinit()
Cold Boot - power down at 14:13:30.00 16/05/13
Time is now 15:02:48.74 16/05/13
codian: kupgrade
card ready
card ready
100%  10240      21.53 KB/s    00:00 ETA
Extracting root fs
  0%  32768      29.72 KB/s    29:10 ETA
  0%  49152      22.94 KB/s    37:46 ETA
  0%    160 KB   52.02 KB/s    16:37 ETA
  1%    928 KB  229.92 KB/s    03:42 ETA
  3%   1680 KB  334.43 KB/s    02:30 ETA
  4%   2544 KB  420.67 KB/s    01:57 ETA
  5%   3008 KB  427.91 KB/s    01:54 ETA
  6%   3152 KB  391.42 KB/s    02:04 ETA
  7%   3856 KB  421.71 KB/s    01:54 ETA
  7%   4048 KB  403.03 KB/s    01:59 ETA
  9%   4752 KB  429.84 KB/s    01:50 ETA
10%   5520 KB  458.51 KB/s    01:41 ETA
12%   6339 KB  486.41 KB/s    01:33 ETA
13%   7171 KB  512.10 KB/s    01:27 ETA
15%   8031 KB  535.28 KB/s    01:22 ETA
16%   8835 KB  551.18 KB/s    01:18 ETA
18%   9667 KB  566.76 KB/s    01:14 ETA
20%  10439 KB  579.85 KB/s    01:11 ETA
21%  11277 KB  592.02 KB/s    01:08 ETA
23%  12031 KB  601.39 KB/s    01:06 ETA
24%  12850 KB  611.10 KB/s    01:04 ETA
26%  13667 KB  621.15 KB/s    01:01 ETA
27%  14467 KB  628.81 KB/s    00:59 ETA
29%  15296 KB  637.14 KB/s    00:57 ETA
30%  16114 KB  643.84 KB/s    00:55 ETA
32%  16963 KB  652.12 KB/s    00:53 ETA
34%  17795 KB  658.55 KB/s    00:52 ETA
35%  18691 KB  666.35 KB/s    00:50 ETA
37%  19442 KB  670.04 KB/s    00:48 ETA
38%  20274 KB  674.20 KB/s    00:47 ETA
40%  21123 KB  680.20 KB/s    00:45 ETA
42%  21955 KB  685.58 KB/s    00:43 ETA
43%  22815 KB  691.27 KB/s    00:42 ETA
45%  23603 KB  694.12 KB/s    00:40 ETA
46%  24370 KB  695.38 KB/s    00:39 ETA
48%  25216 KB  699.24 KB/s    00:38 ETA
50%  26051 KB  703.34 KB/s    00:36 ETA
51%  26883 KB  706.80 KB/s    00:35 ETA
53%  27713 KB  708.72 KB/s    00:34 ETA
54%  28481 KB  711.04 KB/s    00:33 ETA
56%  29248 KB  713.03 KB/s    00:31 ETA
57%  30015 KB  714.51 KB/s    00:30 ETA
59%  30784 KB  715.34 KB/s    00:29 ETA
60%  31617 KB  717.95 KB/s    00:28 ETA
62%  32415 KB  720.27 KB/s    00:27 ETA
63%  33132 KB  719.29 KB/s    00:26 ETA
65%  34106 KB  725.61 KB/s    00:24 ETA
67%  34941 KB  727.45 KB/s    00:23 ETA
68%  35812 KB  730.68 KB/s    00:22 ETA
70%  36933 KB  738.31 KB/s    00:20 ETA
71%  37213 KB  729.33 KB/s    00:20 ETA
72%  37705 KB  724.79 KB/s    00:19 ETA
72%  37961 KB  716.06 KB/s    00:19 ETA
73%  38457 KB  712.05 KB/s    00:19 ETA
74%  38949 KB  707.33 KB/s    00:18 ETA
76%  39625 KB  707.47 KB/s    00:17 ETA
77%  40386 KB  707.59 KB/s    00:16 ETA
78%  40855 KB  704.30 KB/s    00:15 ETA
79%  41377 KB  701.27 KB/s    00:15 ETA
79%  41627 KB  693.72 KB/s    00:15 ETA
80%  41983 KB  688.20 KB/s    00:14 ETA
81%  42607 KB  686.30 KB/s    00:13 ETA
82%  43120 KB  684.23 KB/s    00:13 ETA
83%  43552 KB  679.97 KB/s    00:12 ETA
85%  44305 KB  681.44 KB/s    00:11 ETA
86%  45055 KB  682.57 KB/s    00:10 ETA
87%  45742 KB  682.11 KB/s    00:09 ETA
89%  46412 KB  682.31 KB/s    00:08 ETA
89%  46428 KB  672.45 KB/s    00:08 ETA
89%  46428 KB  663.08 KB/s    00:08 ETA
90%  46892 KB  660.04 KB/s    00:07 ETA
91%  47657 KB  661.72 KB/s    00:06 ETA
92%  48266 KB  659.65 KB/s    00:05 ETA
93%  48634 KB  655.36 KB/s    00:05 ETA
94%  49114 KB  654.24 KB/s    00:04 ETA
94%  49194 KB  646.05 KB/s    00:04 ETA
94%  49242 KB  639.08 KB/s    00:04 ETA
94%  49322 KB  630.83 KB/s    00:04 ETA
94%  49370 KB  624.69 KB/s    00:04 ETA
94%  49434 KB  617.75 KB/s    00:04 ETA
96%  50058 KB  617.68 KB/s    00:03 ETA
97%  50747 KB  618.31 KB/s    00:02 ETA
98%  51269 KB  617.63 KB/s    00:01 ETA
99%  51876 KB  617.38 KB/s    00:00 ETA
99%  51892 KB  610.23 KB/s    00:00 ETA
99%  51908 KB  603.25 KB/s    00:00 ETAcardslot_event_throw: an event 16-bit Card removed comes
cardslot1: removal event
99%  51908 KB w 594.20 KB/s    d00:00 ETA1 detached
atabus1 detached
wdc1 detached
99%  51908 KB  589.69 KB/s    00:00 ETA
99%  51924 KB  583.34 KB/s    00:00 ETA
99%  51940 KB  576.83 KB/s    00:00 ETA
99%  51956 KB  570.71 KB/s    00:00 ETA
99%  51956 KB  564.62 KB/s    00:00 ETA
99%  51972 KB  558.68 KB/s    00:00 ETA
99%  51988 KB  552.72 KB/s    00:00 ETA
99%  51988 KB  547.06 KB/s    00:00 ETA
99%  52004 KB  536.07 KB/s    00:00 ETA
99%  52020 KB  530.79 KB/s    00:00 ETA
99%  52020 KB  525.21 KB/s    00:00 ETA
99%  52020 KB  519.91 KB/s    00:00 ETA
99%  52036 KB  515.04 KB/s    00:00 ETA
100%  52050 KB  510.21 KB/s    00:00 ETA
100%  52050 KB  505.27 KB/s    00:00 ETA
100%  52050 KB  500.46 KB/s    00:00 ETA
100%  52050 KB  499.72 KB/s    00:00 ETA
Installing etc
Installing kernel
May 16 15:04:56 reboot: rebooted by rootsyncing disks... done
rebooting
*** (C) Codian Ltd 2004-2005 ***
Resetting PCI
Calling Mpc107init
Mpc107init done
Testing SDRAM data lines ... ok
Testing SDRAM address lines ... ok
Relocating .text from FFF00000-FFF0B36E to 0E010000
Relocating .data from FFF0B380 to 0E01B380-0E01B7C8
Clearing .bss from 0E01B7C8-0E09EDA4
Initialising timebase regs
Calling main
L1 strap : built at Jul  7 2005 - 23:19:46
L2 found : image size 000362e4 version 2005:07:08 11:19
Starting L2
L2 Bootstrap
Relocating .text from FFF10000-FFF450B0 to 0E010000
Relocating .data from FFF450C0 to 0E0450C0-0E0462E4
Clearing .bss from 0E0462E4-0E0CA930
Calling main
Hello from l2_main
card detected in internal slot (EXCA_STATUS = 4c)
waiting until status ready ...ok!
mounting dos0
fatsize = 00010000
Slotmask : 00000008
Devmode : 00000000
Trying dos0:netbsd
fd=6
loadelf line 78
loadelf line 86
loadelf line 93
loadelf line 150
loadelf line 165
loadelf line 178
loadelf line 200
loadelf line 200
ok
MARK[0] = 00090000
MARK[1] = 00090000
MARK[2] = 00000001
MARK[3] = 0044fb8c
MARK[4] = 00490740
ksyms_init
cpu0: HID0 90c000
eumbbus_submatch
sc_ioh=fc004500
com0: console
00011120
eumbbus_submatch
sc_ioh=fc004600
00011140
about to setup pci
line=0xff
line=0x00
line=0x01
line=0x0c
line=0x0f
line=0x0f
configure_bus 0
configure_bridge 1
configure_bus 1
configure_bridge 2
configure_bus 2
pci_mem_find
pci_mem_find
pci1 at ppb0 bus 1
pci2 at ppb1 bus 2
res=80000000
sock_base=80000000
pci_mem_find
res=80001000
sock_base=80001000
pci_mem_find
000103e0
000103e0
mainbus attach done
kthread_create
ccdattach
i2c_attach
board_init
pcmcia card attach
card ready
card ready
memory mapped mode
card ready
card ready
card ready
card ready
rtcinit()
Warm Boot
Time is now 15:05:39.48 16/05/13
May 16 15:05:42 init: /etc/pwd.db: No such file or directoryfsck: Cannot open `/etc/fstab': No such file or directory
** /dev/rwd0b
** /dev/rwd0d
** Phase 1 - Check Blocks and Sizes
** Phase 2 - Check Pathnames
** Phase 3 - Check Connectivity
** Phase 4 - Check Reference Counts
** Phase 5 - Check Cyl groups
MARK FILE SYSTEM CLEAN? yes
***** FILE SYSTEM MARKED CLEAN *****
***** FILE SYSTEM WAS MODIFIED *****
RUNNING MCU
stack at 0xffffdbc0
ftrace_init done
user mbuf init
sendbatch_init
150602.308 SYSTEM : Info : Cisco TelePresence MCU 4505 4.4(3.49) (Build 6.18(3.49)) starting
150602.496 SYSTEM : Info : device configuration successfully loaded
ssl init
150606.042 HEALTH_MONITOR : Info : Temperature 0 = 34.5
150606.047 HEALTH_MONITOR : Info : Temperature 1 = 34.5
150606.048 SYSTEM : Info : Disabling core dumps
150606.069 UPGRADE : Info : clearing local features cache
150606.121 CLUSTER : Info : feature enabled
150606.251 PIPELOG : Info : network control initialised
150606.272 NETWORK : Info : Initialising IP routes
150606.332 NETWORK : Info : Failed to read network services configuration; assuming default settings
150606.416 NETWORK : Info : Failed to read network services configuration; assuming default settings
150606.422 NETWORK : Info : Failed to read network services configuration; assuming default settings
150606.662 NETWORK : Info : activating ethernet Port A with auto-negotiation
150606.704 NETWORK : Info : activating ethernet Port A with auto-negotiation
150606.744 NETWORK : Info : deactivating port A IPv6
150606.746 NETWORK : Info : activating ethernet Port B with auto-negotiation
150606.793 NETWORK : Info : activating ethernet Port B with auto-negotiation
150606.834 NETWORK : Info : deactivating port B IPv6
150606.835 NETWORK : Info : activating ethernet Port A with auto-negotiation
150606.875 NETWORK : Info : activating port A IPv4 with fixed IP parameters
150606.881 NETWORK : Info : activating ethernet Port B with auto-negotiation
150606.923 NETWORK : Info : deactivating port B IPv4
150607.050 NETCONF : Info : Added route 0.0.0.0/0x0 192.168.1.1
150617.105 UPGRADE : Info : Hardware compatibility: 00000002 / 00000002
150617.740 USER_MANAGER : Info : 2 users present
150617.770 CUSTOMIZATION : Info : customisation configuration read; starting with 1-off 2-off
150617.781 CUSTOMIZATION : Info : Doing customisation resources init
150618.595 SYSTEM : Info : default text tokens loaded - 6889 tokens (UTF-8 format)
150618.600 RECORD_STORAGE : Info : record_storage module initialised
shell initshell init150633.821 SYSTEM : Info : Unique id initialised
150633.822 SHELL : Info : Serial shell unsecured
150633.823 SHELL : Info : Serial shell in recovery mode.
150633.992 CAPABILITIES : Info : Creating 162 capability sets
150634.090 SYSTEM : Info : Unique id change thread starting
MCU:>
MCU:> 150634.602 SIP : Info : SIP initialised
150635.048 AUTO_ATTENDANT : Info : initialised - 1 present
150635.136 API : Info : initialised database
150635.768 CONFERENCE : Info : initialising font support
user mbuf init
pci_init()
MARBR=00200000
....................................................................................................................................................................................................................................................................................................................150647.291 SYSLOG : Info : sending IPv4 from default port
150647.291 SYSLOG : Info : sending IPv6 from default port
bitstream load done
rx poll start
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:> fan status ok
MCU:>
MCU:>
MCU:>
MCU:>
MCU:> done
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:> \
Incomplete input line
MCU:>
MCU:>
MCU:> configure_db_fpga2 db6455_rp_2.bit 70000000
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:> done
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:> enabling mezz link port rx
sh[0]=02 sh[1]=01 sh[2]=01 sh[3]=01 num_slots=00000004
slot 0 height 0 set router id 00000000
slot 1 height 0 set router id 00000001
slot 2 height 0 set router id 00000002
slot 3 height 0 set router id 00000003
slot 0 height 0 pulse prog 0
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:> slot 0 height 0 pulse prog 1
slot 0 height 0 set_link_enable
slot 0 height 1 set router id 00000004
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:>
MCU:> DSP_TRACE(ff) : dsp : init done
opening DSP 00000000
opening DSP 00000001
opening DSP 00000002
opening DSP 00000003
opening DSP 00000010
opening DSP 00000011
opening DSP 00000012
opening DSP 00000013
opening DSP 00000020
opening DSP 00000021
opening DSP 00000022
opening DSP 00000023
opening DSP 00000030
opening DSP 00000031
opening DSP 00000032
opening DSP 00000033
opening DSP 00000100
opening DSP 00000101
opening DSP 00000102
opening DSP 00000103
opening DSP 00000110
opening DSP 00000111
opening DSP 00000112
opening DSP 00000113
opening DSP 00000120
opening DSP 00000121
opening DSP 00000122
opening DSP 00000123
opening DSP 00000130
opening DSP 00000131
opening DSP 00000132
opening DSP 00000133
opening DSP 00000200
opening DSP 00000201
opening DSP 00000202
opening DSP 00000203
opening DSP 00000210
opening DSP 00000211
opening DSP 00000212
opening DSP 00000213
opening DSP 00000220
opening DSP 00000221
opening DSP 00000222
opening DSP 00000223
opening DSP 00000230
opening DSP 00000231
opening DSP 00000232
opening DSP 00000233
opening DSP 00000300
opening DSP 00000301
opening DSP 00000302
opening DSP 00000303
opening DSP 00000310
opening DSP 00000311
opening DSP 00000312
opening DSP 00000313
opening DSP 00000320
opening DSP 00000321
opening DSP 00000322
opening DSP 00000323
opening DSP 00000330
opening DSP 00000331
opening DSP 00000332
opening DSP 00000333
loading symtab
150847.347 SYSTEM : Info : mutex 0x3408AB4 (&mps_connection_mutex) locked for 131.433s by /stripe/builduser/CAAGDKRF/mcu_release_6_18_3/shared/mp_streams/zaphod_mp_streams_msg.cpp:1070
150847.401 SYSTEM : Info : Unique id looking for file with name "/rdwr/persistent_id/conference_id.uid"
150847.405 SYSTEM : Info : Successfully opened file and read starting id as 764000
150847.567 SYSTEM : Info : Unique id "conference_id" was written; new allocation is 766000
MCU:> 150849.884 SYSTEM : Info : mutex 0x3620BE8 (&conference_manager_mutex) locked for 134.741s by /stripe/builduser/CAAGDKRF/mcu_release_6_18_3/mcu/conference_manager/conference_manager_api.cpp:1396
150850.073 SIP : Info : Starting SIP TCP service
150850.074 SIP : Info : Starting SIPS TCP service
150850.074 SIP : Info : Starting SIP UDP service
150850.111 NETWORK : Info : Registering tunnel prefix with http handler
150850.123 WEB_PAGES : Info : page services initialised
150850.892 WEB_PAGES : Info : Regenerating help page index
150854.529 API : Info : shared components initialised
150854.530 API : Info : initialised
load done on 0x6b8d060 866
hsi at 0090b544
loading symtab
DSP(00000000) : os_error:ring_handler stack: local 0x90F88C (0x11111111) ... global 0xE00CB560 (0x0)
DSP(00000000) : os_error:*** DSP_ID=0x0 booted (rev = 0x00010001)
DSP(00000000) : os_error:vs_thread stack: local 0x996424 (0x33333333) ... global 0xE003901C (0x0)
DSP(00000000) : os_error:as_thread stack: local 0x9983A4 (0x22222222) ... global 0xE00CCC58 (0x0)
reg done
DSP(00000000) : **** mpvs_ip_init returning
load done on 0x6b8d0a0 142
hsi at 0090b544
loading symtab
DSP(00000001) : os_error:ring_handler stack: local 0x90F88C (0x11111111) ... global 0xE00CB560 (0x0)
DSP(00000001) : os_error:*** DSP_ID=0x1 booted (rev = 0x00010001)
DSP(00000001) : os_error:vs_thread stack: local 0x996424 (0x33333333) ... global 0xE003901C (0x0)
DSP(00000001) : os_error:as_thread stack: local 0x9983A4 (0x22222222) ... global 0xE00CCC58 (0x0)
reg done
DSP(00000001) : **** mpvs_ip_init returning
150859.298 MEDIA_STREAMS : Info : all DSPs now initialised
150901.518 CONFERENCE : Info : audio resource 1 now available
load done on 0x6b8d0c0 548
150905.304 CONFERENCE : Info : video resource 1 now available
hsi at 0090b544
loading symtab
DSP(00000002) : os_error:ring_handler stack: local 0x90F88C (0x11111111) ... global 0xE00CB560 (0x0)
DSP(00000002) : os_error:*** DSP_ID=0x2 booted (rev = 0x00010001)
DSP(00000002) : os_error:vs_thread stack: local 0x996424 (0x33333333) ... global 0xE003901C (0x0)
DSP(00000002) : os_error:as_thread stack: local 0x9983A4 (0x22222222) ... global 0xE00CCC58 (0x0)
reg done
DSP(00000002) : **** mpvs_ip_init returning
150906.064 CONFERENCE : Info : video resource 2 now available
load done on 0x6b8d0e0 191
hsi at 0090b544
loading symtab
DSP(00000003) : os_error:ring_handler stack: local 0x90F88C (0x11111111) ... global 0xE00CB560 (0x0)
DSP(00000003) : os_error:*** DSP_ID=0x3 booted (rev = 0x00010001)
DSP(00000003) : os_error:vs_thread stack: local 0x996424 (0x33333333) ... global 0xE003901C (0x0)
DSP(00000003) : os_error:as_thread stack: local 0x9983A4 (0x22222222) ... global 0xE00CCC58 (0x0)
reg done
DSP(00000003) : **** mpvs_ip_init returning
150908.681 CONFERENCE : Info : video resource 3 now available
load done on 0x6b8d280 181
hsi at 0090b544
loading symtab
DSP(00000100) : os_error:ring_handler stack: local 0x90F88C (0x11111111) ... global 0xE00CB560 (0x0)
DSP(00000100) : os_error:*** DSP_ID=0x100 booted (rev = 0x00010001)
DSP(00000100) : os_error:vs_thread stack: local 0x996424 (0x33333333) ... global 0xE003901C (0x0)
DSP(00000100) : os_error:as_thread stack: local 0x9983A4 (0x22222222) ... global 0xE00CCC58 (0x0)
reg done
DSP(00000100) : **** mpvs_ip_init returning
150910.819 CONFERENCE : Info : audio resource 2 now available
load done on 0x6b8d2a0 181
hsi at 0090b544
loading symtab
DSP(00000101) : os_error:ring_handler stack: local 0x90F88C (0x11111111) ... global 0xE00CB560 (0x0)
DSP(00000101) : os_error:*** DSP_ID=0x101 booted (rev = 0x00010001)
DSP(00000101) : os_error:vs_thread stack: local 0x996424 (0x33333333) ... global 0xE003901C (0x0)
DSP(00000101) : os_error:as_thread stack: local 0x9983A4 (0x22222222) ... global 0xE00CCC58 (0x0)
reg done
DSP(00000101) : **** mpvs_ip_init returning
150913.562 CONFERENCE : Info : video resource 4 now available
load done on 0x6b8d2c0 193
hsi at 0090b544
loading symtab
DSP(00000102) : os_error:ring_handler stack: local 0x90F88C (0x11111111) ... global 0xE00CB560 (0x0)
DSP(00000102) : os_error:*** DSP_ID=0x102 booted (rev = 0x00010001)
DSP(00000102) : os_error:vs_thread stack: local 0x996424 (0x33333333) ... global 0xE003901C (0x0)
DSP(00000102) : os_error:as_thread stack: local 0x9983A4 (0x22222222) ... global 0xE00CCC58 (0x0)
reg done
DSP(00000102) : **** mpvs_ip_init returning
150916.266 CONFERENCE : Info : video resource 5 now available
load done on 0x6b8d2e0 174
hsi at 0090b544
loading symtab
DSP(00000103) : os_error:ring_handler stack: local 0x90F88C (0x11111111) ... global 0xE00CB560 (0x0)
DSP(00000103) : os_error:*** DSP_ID=0x103 booted (rev = 0x00010001)
DSP(00000103) : os_error:vs_thread stack: local 0x996424 (0x33333333) ... global 0xE003901C (0x0)
DSP(00000103) : os_error:as_thread stack: local 0x9983A4 (0x22222222) ... global 0xE00CCC58 (0x0)
reg done
DSP(00000103) : **** mpvs_ip_init returning
150918.764 CONFERENCE : Info : video resource 6 now available
EXIT 1
May 16 15:09:20 reboot: rebooted by rootsyncing disks... done
rebooting
Nikhil
Hi Nikhil - All your DSP's don't seem to be booting up.  When the code is trying to right to DSP 10 after DSP 103 starts, it seems to fail, times out and reboots.  This looks like a HW problem and perhaps an issue with DSP 10 on this unit and should be RMA'ed as soon as possible.  Please call in and provide this log in the support case, and have the unit RMA'ed.
VR
Patrick
Hello Nikhil
also the the same error of kupgrade is seen and the upgrade have not helped. Please raise a TAC case and RMA the box as Patrick suggested.
Sundar
