MCU/TC reg on VCSE - FW ports?
johan.alkarp
Hi all,
Customer has previously invested in a VCSE starterpack and are now about to add a MCU 4210 and TC. So would like to check the ports used for registering to a VCSE through a firewall, found the below ports on Cisco site, but would like to confirm them, and if they are the same towards a VCSE?
Taken from :
http://www.cisco.com/en/US/docs/telepresence/infrastructure/articles/conferencing_products_conferenceme_ports_used_kb_3.shtml
MCU ports
Incoming calls
H.323 -> TCP:1720 (TCP 1720 Q931/H225 signaling)
Q921/H225 - TCP 49152-65535 <->49152-65535
Outgoing calls
MCU TCP 49152-65535 -> VCSE TCP 1720
MCU TCP 49152-65535 -> VCSE TCP 5060
MCU TCP 49152-65535 -> VCSE TCP 5061
MCU UDP 49152-65535 <-> VCSE UDP 49152-65535
Content server:
VCSE->Content - TCP 3230-3235 - Q.931 / H225 signaling
VCSE <-> MCU UDP 3230-3259 - RTP/RTCP
Thanks for any help on this
// Johan
ahmashar
Level 4
Level 4
Hi Johan,
can you list the software version of MCU and VCSE (and any other component that is supposed to register/communicate via VCSE)?
regards,
Ahmad
On the VCSE there will be end-points registrating using assent, both on inside and outside the firewall.
Sw version will be x7.2 and 4.3.
Hopefully we will be able add a VCSC instead of this solution, might put the MCU on public instead, but either way it will require opening range in the FW.
// Johan
Could you make a small drawing on how your network looks like?
Especially regards firewalls, possible NAT, ... and as well if you use something like the dual interface option key.
Descrive everything in the way in beteen endpoints/other infrastructure ( like the mcu)  and the vcs-e sp.
Be aware that neither the content server nor the MCU support assent nor h460.18, so they shall not be behind NAT.
Regards the ports itself, the VCS is quite handy as it lists on its webinterface under maintanance > port usage > *
its in/out ports. You can find some more info about the flow here:
http://www.cisco.com/en/US/docs/telepresence/infrastructure/vcs/config_guide/Cisco_VCS_IP_Port_Usage_for_Firewall_Traversal_Deployment_Guide_X7-2.pdf
Here is a faq regards the codian:
With these info you can compile your firewall rules.
