04-14-2016 12:57 AM - edited 03-18-2019 05:48 AM
Dear Forum,
we have mediasense, and ofcourse added a new user into mediasense.
can i actually have 1 user mediasense to manage just only 1 phone/ext?
in our deployment, we created 6 user for 6 ext. when we put into mediasense, all 6 user share recent calls. how can we have just 1 user mediasense only to manage 1 phone. (or have partition between user view)
please advice.
regards,
04-14-2016 10:21 AM
If I understand you correctly, you are talking about Search & Play option within MediaSense. A single MediaSense API user should be able to manage, download recordings etc for all the users if that what your Quesion Is. You do not need a separate user to manage their recordings individually within Ms Search & Play.
Deepak
04-15-2016 12:14 AM
Hi Deepak,
thanks for your answer.
ya, im talking about search & play in MS. that is exactly what i mean. but i want to separate user to manage their recording, can MS do that?
regards,
04-15-2016 12:26 AM
Ok so you want the recordings should be limited on per user basis within S&P. Unfortunately that option is not available with MS, it is all or none as of now. However 11.5 should have it, check below:
https://communities.cisco.com/thread/57787
Deepak
04-15-2016 02:28 AM
thank you very much,
this is very important feature i think, and hope 11.5 can resolve this.
04-15-2016 02:50 AM
As per the information on the thread I shared earlier, it should be fixed in 11.5 rest we will need to wait for it to out and then check. Please remember to mark the thread as Answered if there are no further question on the topic.
Deepak
