Microsoft NetMeeting and VoIP
gilson_machado
I had a problem with users using NetMeeting that took all data bandwidth for the Frame Relay port that I shared with a PVC for VoIP over Frame Relay.
My QoS is corrected - revised by Cisco TAC - and the bandwidth allocation is correct. The results were that teh users could not make the NetMeeting session. I would like to know if it is a known problem of compatibility.
Does anyone knows about anyproblems like that?
beth-martin
Level 5
Level 5
You must consider adding some QoS for the Netmeeting sessions as well. May be the TAC has configured QoS only for VoIP and Netmeeting is still a Best effort traffic.
