Showing results forĀ
Search instead forĀ
Did you mean:Ā
microsoft teams rooms on Room kit EQ
rivent
anyone got any idea why Cisco room kit EQ running software version 11.9.2.4 does not have the ability on setup to choose microsoft teams platform? the only option is Cisco RoomOS
8 Replies 8
Are you using a Touch10 or a Room navigator?
Please let me know
Carlo
Please rate all helpful posts "The more you help the more you learn"
i am using a Cisco room navigator
rivent
view of the platform selection
Have you tried to  perform a factory reset using the factory reset pinhole next to USB ports?
Please let me know
https://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/roomos-119/desk-room-board-administration-guide-roomos-119.pdf
Carlo
Doing a factory reset using the pinhole did not fix the problem
Rivent,
Did you ever figure this out, I am seeing the same issue.
Please follow this steps:
- Factory reset the Room
- install CE version 11.5.3 from here https://software.cisco.com/download/home/286331678/type/280886992/release/RoomOS%2011.5.3.3
- Register the Room to webex.
Let it upgrade and reset it again.
Please let me know
Carlo
Good guide start here
https://roomos.cisco.com/doc/MTR
Then look at Requirements for Codec EQ https://roomos.cisco.com/doc/MTR/Requirements
ashish
Response Signature
