12-17-2015 12:38 PM - edited 03-18-2019 05:20 AM
Hey Community,
I've to migrate a expressway c and expressway e from one be6k server with esxi free edition to another be6k server with esxi.
After I exported the virtual machine and imported it on the new system the expressway has a newly generated serial number and therefore all my licenses are gone ...
within the docu it is recommended to migrate a expressway with a vcenter ...
has anyone a hint for me?
Thanks for support :)
best regards, thomas
12-17-2015 02:12 PM
The only supported method is using vMotion, exporting the VM is the same as copying it and as such will generate a new serial number as you've seen, refer to the "Supported Features" and "Unsupported Features" in the Expressway Install Guide on pg 17.
I don't know anything really about VMWare, but is it possible to join the two environments together so you can migrate the VM using vMotion?
12-17-2015 02:38 PM
Why didn't you do a cold migration??
12-17-2015 10:49 PM
Hey :)
thanks for your answer ... what is a "cold migration"? :)
... I have no chance to install a vcenter in the environment.
br, Thomas
12-17-2015 11:44 PM
https://pubs.vmware.com/vsphere-50/index.jsp?topic=%2Fcom.vmware.vsphere.vcenterhost.doc_50%2FGUID-326DEC3C-3EFC-4DA0-B1E9-0B2D4698CBCC.html
If you simply google: esxi cold migration, you can find plenty of information, and even videos
