Mistake in administration guide for TC / SX Series 7.x
tec cou
Hi ,
I think this mistake ..
example :
http://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/codec-c-series/tc7/administration-guide/profile-c60-c40-and-codec-c60-c40-administrator-guide-tc71.pdf
appendice:
ClearPath — Packet loss resilience
ClearPath introduces advanced packet loss resilience
mechanisms that increase the experienced quality when you
use your video system in an error prone environment.
We recommend that you keep ClearPath enabled on your
video system.
Go to Advanced configuration (menu on screen) or open the
System Configuration page (web interface):
• Navigate to Conference 1 > PacketLossResilience > Mode
Choose Off to disable ClearPath and On to enable
ClearPath.
Correct is Experimental -> Conference 1-> PacketLossResilience
good day  !!!
Wayne DeNardi
As this is a community support forum, I'd suggest you log this with the TAC as a defect on the documentation - they can then assign it to the correct business unit to have it fixed.
PS - this setting no longer appears in the newer TC7.2.x software, only settings for RateAdaption (On/Off) and ForwardErrorCorrection (Off/XOR/XORWithUniqueSsrc/ReedSolomon).
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Martin Koch
There is at least a forum dealing with documentation, so maybe its worth posting it there:
https://supportforums.cisco.com/community/4886/technical-documentation-ideas
Besides reporting it through TAC can be an option as well.
These are the current options:
xConfiguration Experimental Conference[1] PacketLossResilience ForwardErrorCorrection: <Off, XOR, XORWithUniqueSsrc, ReedSolomon>
xConfiguration Experimental Conference[1] PacketLossResilience RateAdaption: <Off, On>
xConfiguration Experimental Conference[1] ReceiverBasedDownspeeding: <Off, On>
