Movi 3.0 provisioning xml file
Bob Fitzgerald
Level 4
Level 4
Hello!
Does anyone have a copy of the provisioning configuration template xml for Movi 3.0.  I can't find one anywhere.
Thanks!
Patrick Sparkman
Hi Patrick,
Yeah, looked there.  They didn't start including the xml file in the zip package until Movi 4.  Thanks though.
I just checked my TMS which is running TMS Agent Legacy, and by default up to Movi v3, the XML files are already added to the provisionting templates list.  This particular TMS instance was a fresh install about two weeks ago.
