MRA + Dedicated TFTP Server
Hi, folks
I am trying to deploy MRA in an environment wit ha dedicated TFTP. Dedicated TFTP means CUCM running the TFTP service only (no CUCM service).
The server is not discovered by Exp-C, if the CUCM service is not running. I am avoiding to enable the cucm service on this server because I am very close to the maximum of call control number.
I've tried to create HTTP allow list, but the Exp-C just try to get the xml file from the servers auto-discovered,
Some have been deployed MRA using a dedicated TFTP server?
Anurag Srivastava
MRA is used for to remotely register your Jabber/endpoints to CUCM without a VPN.
So without Call manager service it will not work.
But if you don't want to use calling services you should not associate device/phone profile to your end users and by that way they will only use IM&P.
You can also use service profile for IM&P only.
Please let me know if it is helpful
