Multisite deployment
ahakouz011
Hello , i have to implement multisite video conferencing between sites using (sx10 ,sx20,dx80 ,and jabber clients+spa300 ip phone  ) and i have be6ks for this purpose , do i need extra MCU in the MRLG or i can use the internal sx20 MCU for that, and if i use it , is it should be involved in the conference in order to make that conference ? any help or useful document for that case ?
2 Accepted Solutions
Jens Didriksen
Level 9
Level 9
You can use the internal MCU in the SX20, however, it has to be in the call as it will host it. This means you can only have a maximum of 3 additional sites in the conference; SX20+3=4.
If that is not enough, yes, then you will need a MCU, whether you deploy one on premise, or use a hosted cloud-based solution is up to you. Depends on intended usage and economics.
/jens
Please rate replies and mark question(s) as "answered" if applicable.
The internal MCU of the SX20 would only work if the SX20 is the host of the call.  If you want a multi-site call between any of the other devices that don't support multisite without including the SX20, you'll need a MCU or TelePresence Server.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Jens Didriksen
Level 9
Level 9
/jens
Wayne
Wayne
