04-22-2013 01:30 AM - edited 03-18-2019 12:58 AM
After going through the entire setup, this seems unlikely and impossible. Anyone have an idea how to make it work ?
04-22-2013 08:56 PM
If you use the conductor you could at least define a maximum conference length, so the conference
call gets disconnected after 8 hours or whatever you think should be the max of the conferences.
Besides that you could write yourself some tool which uses the api of the mcu and/or the vcs
and disconnects calls for scenarios you have issues with, like if endpoint in the conference
allone for 10 min: disconnect call.
04-22-2013 11:12 PM
Hi Martin,
Yes, I am completely aware of the possibilities enabled by the Conductor or scripting on the MCU/VCS and so on. The main problem is that these are all additional financial burden options.
04-23-2013 01:54 AM
There is also the manual way, educate your users to hang up when they are out
as well as go in into the mcu/vcs and disconnect old calls.
You could also file a feature request for some automated disconnect.
Besides that there is no automated way I am aware of.
Please rate the postings and set the thread to answered.
