Multiway with Conductor/VCS
George Thomas
Level 10
Level 10
Has someone configured multiway with conductor and VCS using a format other than the {username}.meet format as explained in the configuration guides? Are there any other wildcards/regex that can be used other than {username}?
Please rate useful posts.
5 Replies 5
George,
Yes you can - here's a thread that might help: https://supportforums.cisco.com/discussion/12327146/multiway-uri-and-tmspe
Thanks Nick, however I am in the same boat as you, no TMSPE.
You can still configure multiway to use just about whatever regex you want.  We are only using TMSPE for Jabber/Movi - everything else is either manually configured or configured via TMS.
As an example, we use a "102" prefix, followed by a unit's unique E164 number, followed by our SIP domain e.g. 102(\d+)@ourdomain.com
Conductor seems to accept any Regex a VCS tranform or search rule would, it just has to be a valid SIP URI.
I was hoping to not manually configure the Multiway network address on the endpoint themselves. Was looking to see if its possible to have address automatically generated. .
Yeah I wish that was the case, but you can only do that while using TMSPE.  It's a bit of a gap in capability but unlikely to be fixed because of Cisco's drive to get everyone on CUCM.
The only way for manual/TMS provisioned endpoints to get a multiway URI configured is manually.
