mx 700 and TAB connection via wireless
in MX-700, to control THE UNIT we are using TAB with RJ-45 connection, customer is requesting for wireless connection TAB, kindly let me know is there any.
Or can we connect the existing with access point to control the MX-700, please advice.
Patrick Sparkman
When you refer to TAB, are you speaking of the Touch 10?
If so, the Touch 10 must either be directly connected or paired via LAN to the codec, it doesn't have any wireless capability.  Refer to the Touch 10 Install Guide for reference.
