MX200/300 G1 vs G2
Gurjinder Judge
Does anyone have a good comparision between the MX200/300's G1's and G2's?
Thanks in advance
Patrick Sparkman
Here is an endpoint-product-matrix.pdf that gives an overview of all the TelePresence endpoint products and there features.  Should provide you some good comparison information.  Were you looking for anything specific, or just wondering what the differences were?
Patrick Sparkman
The document Patrick pointed you to has all of the details. If you just want a quick summary the major differences (aside from the obvious differences in the appearance) are:
Cameras - the G1's had 4X optical zoom, the G2's have the 2.5/5X (optical and with 2x digital) on the 200 with a much wider field of view, and the 4/8X on the 300.
Dual screen - G1's had no capability to support a second screen, G2's have the port and it is enabled by default
Multisite - G1's did not offer this as an option, G2's do.
Resolution/frame rate - G2's can do 1080p/60, G1's can do 60fps up to 720p and 30 at 1080p. Also note the premium resolution was an option on G1's it's standard now.
Touch screen - G1 is the Touch 8, G2 is the Touch 10.
Intelligent Proximity support - experimental mode only on G1, will be fully supported on G2
Hope this helps.
