MX200 G1 Wallmount
paulcan01
Hello, all.
Anyone know of a compatible wall-mount kit for an MX200 G1?  These are EOS.  G2 kits don't work!  Thanks in advance for any guidance-
pjc
Patrick Sparkman
The MX200 G2 uses a bracket with 2 pins that the endpoint rests on, you might be able to find one online using a third-party re-seller, or someone that is getting rid of old equipment.  You could reach out to your Account Manager, they might be able to give you some ideas or work out some kind of deal to upgrade you to an MX200 G2.
