MX300 G2 SerialPort Baudrate change
Georg Kehrer
Level 4
Level 4
Dear all
Anyboda an Idea how can I hcnage the SerialPort Baudrate on a MX300 G2 ?
I getting allways the follwoing failure :
xconfiguration SerialPort BaudRate: 115200
*r Configuration (status=Error):
*r Configuration Reason: "No match on address expression."
*r Configuration XPath: "Configuration/SerialPort/BaudRate"
** end
Is it not possible to Change anymore ?
any Feedback appreciated.
Thank you
Best Regards
Georg
6 Replies 6
Patrick Sparkman
You don't mention which software version you're running, as the API can sometimes change from one version to another.
Looking at the MX200/300 G2 CE8.2 API Guide, there doesn't appear to be a configuration anymore for changing the baud-rate, however on pg 28 under "RS-232/serial connection" it mentions it can be.  So, I would say if there isn't any type of option on the web interface or if you list all the xConfiguration commands and don't see SerialPort BaudRate, I'd presume there isn't one anymore for this particular endpoint/software version.
yes it's Version CE8.2.1, we have opened a TAC case to clarify this questions.
regards
Georg
The baud rate cannot be changed.  Is just 115200.
Tang
CSCvb31985. Request to Update API doc(latest CE8.x) for SX10 (page 29) , MX200/MX300 G2 (page 28) to prevent confusion.
Hi Tang
Thanks for the answer.
Regarding the CSCvb31985. I don't have access or with my account or don't find this Bug.
Another questions:
On the MX300G2 are micro USB and also UBS available, can I use both USB Port for Serial Connections?
Which Serial RS232 USB adapter are recomended?
because it exist different adapter with different Chipset.
Georg
use the micro USB port.
I do not have any model to recommend.  But as long as drivers of the USB-Serial cable/adapter(if needed) are installed properly , I would think it should work.
