MX300 TMS CONNECTION WARNING ERROR
Chet Cronin
Level 4
Level 4
I have an MX300 running TC7.3.5
I have TMS running 15.3.0
Getting the following error each time I try to add system to TMS:
System not found!
Please check that the address to the system is correct, and that the system can be contacted by the TMS server. Also, check that the SNMP community name set for the system is listed under the 'SNMP community name' setting under Administrative Tools -> Configuration -> Network Settings. Also, it is mandatory to enter the Username and Password for the Cisco Meeting Server
Also noticed provisioning keeps is timed out.
I added the screen shot of the MX300 Provisioning settings if that is the issue.
Chet Cronin
0 Replies 0
