01-09-2019 09:00 PM - edited 03-18-2019 02:34 PM
Got an MX800 running TC7.3.7. The Left Monitor no longer display's video, local or remote. I pull the HDMI cable from the codec and video pops up on right monitor fully functional. Has anyone else had this issue.
I have reset the codec, I have re-installed the firmware but still no joy. The left monitor is getting power just no video.
I did bypass the hdmi cable from the monitor to the codec with a known good HDMI cable and still no joy. I did move the hdmi cable from the right monitor to the left monitor and no video.
I verified both hdmi outputs work from the codec to the right monitor.
Solved! Go to Solution.
01-10-2019 12:20 AM
Hello Chet,
Please connect your left monitor HDMI directly to a laptop and see if you are getting video or not.
If still not, probably left display has gone faulty and you can raise a RMA with Cisco for this.
Thanks.
Please rate if it is helpful..
01-10-2019 12:20 AM
Hello Chet,
Thanks.
