No auto QoS on 6509-E?
Josh Morris
Level 3
Level 3
I am trying to run auto qos on a 6509-E but the option isn't there. I have tried enabling mls qos from global config, but the auto qos under interface config mode still doesn't show up. Any ideas? We need to use auto qos as a temporary measure. Thanks.
IOS version 12.2(18)SXF8
MDF#show mod
Mod Ports Card Type                              Model              Serial No.
  1    8  8 port 1000mb GBIC Enhanced QoS        WS-X6408A-GBIC
  2   48  48-port 10/100/1000 RJ45 EtherModule   WS-X6148A-GE-TX
  3   48  48 port 10/100/1000mb EtherModule      WS-X6148-GE-TX
  4   48  48 port 10/100/1000mb EtherModule      WS-X6148-GE-TX
  5    9  Supervisor Engine 32 8GE (Active)      WS-SUP32-GE-3B
  6   48  48 port 10/100/1000mb EtherModule      WS-X6148-GE-TX
  8   48  48 port 10/100/1000mb EtherModule      WS-X6148-GE-TX
  9   48  48 port 10/100/1000mb EtherModule      WS-X6148-GE-45AF
MDF#sh run int g9/20
Building configuration...
Current configuration : 192 bytes
interface GigabitEthernet9/20
switchport
switchport access vlan 6
switchport mode access
switchport voice vlan 995
no ip address
spanning-tree portfast
end
MDF#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
MDF(config)#int g9/20
MDF(config-if)#auto ?
% Unrecognized command
MDF(config-if)#auto?
MDF(config-if)#au?
Josh Morris
Level 3
Level 3
I have found that auto qos wasn't supported until 12.2(33)SXH.
