No Name for Supervisor Blade on TMS 13.1
Anthony Chan
Have TMS 13.1 running
Upgraded Supervisor Blade 8050 to 2.2 (1.17)
Able to add the Supervisor Blade into TMS
but somehow TMS changed the name from "Fomdo_Sup" to blank
have purged and re-added many times but still get the same result
tried to change name on the Supervisor Blade and did refresh but no change
Below are the log info: (I have replaced certain infos with "xxxx" or "00")
9/17/2011 8:01:39 PM  Serial Number updated from blank to xxxxxxxx
9/17/2011 8:01:39 PM  System name changed from "Fomdo_Sup" to ""
9/17/2011 8:01:38 PM  Connection Status updated to OK
9/17/2011 8:01:28 PM  Connection Status updated to Wrong Password
9/17/2011 8:01:28 PM  System "Fomdo_Sup" Added with IP  Address  xxx.xxx.xxx.xxx, Host Name "", MAC Address "00:00:00:00:00:00" and   Community Name "dmpubc". System is tracked by MAC Address.
Anthony
Patrick Pettit
HI Anthony - Can you verify on Supervisor blade itself under Network>DNS there is a hostname listed here?  Name your supervisor here if one is not listed, click update DNS Configuration and force refresh TMS.  Does it show up with a system name in TMS?  Let me know.  Thanks in advance.
Patrick Pettit
Hi Patrick
thanks that did the trick
Much appreciated
Anthony
