OPENSSL SECURITY ISSUE
Chet Cronin
Level 4
Level 4
I have systems running various firmware versions including:
F9.3.4 (MXP Series)
TC7.3.X (Series)
CE8.2.1 (Series)
X8.8.2  (VCS)
X8.5.1 (VCS)
4.5(1.71) (Codian)
4.5(1.89) (Codian)
J4.7 (MPS)
2.0.1 (Acano/CMS)
We have been directed to upgrade SSL to current Version which I believe is 1.0.1g on all systems that need it.
What firmware versions are using the current version of SSL?
Can I upgrade F9.3.4 locally and if so what is the procedure please ?
If I have to upgrade  VCS, Codian, and MPS versions, Acano/CMS what is the procedure please ?
VR
Chet
Chet Cronin
You cannot individually update a component (like SSL) on any of the devices, you need to upload a complete software kit.
There is no further upgrade for the old MXP devices - F9.3.4 is the latest on those old devices.
For the others - just update to the latest software version availabel for each (TC7.3.9 / CE9.0.1 / X8.9.2, etc).
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Roger that ... looks like we will be replacing the MXP1700's with POLYCOM's Real Presence Desktops.  Got a few hundred of them too.  Hopefully that clears the vulnerabilities.
Thank you for the update.
VR
Chet
Chet Cronin
Patrick Sparkman
Here is the last Cisco Security Advisory, cisco-sa-20170130-openssl,  which can help determine the latest OpenSSL version on some devices, either by being affected by the advisory or doesn't apply (which might mean they're running a version that already contains the fix).
The upgrade process for software is covered in the admin guides and/or release notes for each product.  Most can be done through the web interface, however Acano/CMS requires you to use SFTP and the MMP interface.
