09-04-2014 01:43 AM - edited 03-18-2019 03:22 AM
Hi all,
I have an aging telepresence infrastructure of tandberg/cisco units communicating via H.323 and a couple of tandberg gateways. Generally it works ok.
I have an issue where calls get disconnected about 4 minutes into a conference, sometimes it is just one part in a multi part conference that gets repeatedly disconnected. I have not seen large amounts of packet loss or other clear indicators in the TMS logs, it just says disconnected.
However in the tandberg gatekeeper log i can see several disconnections with the casue "Operator forced termination of call" that match in time with the disconnects people see.
What causes this type of termination? I found no info in the gatekeeper user manual.
Thanks in advance.
09-16-2014 11:56 PM
Anyone?
11-19-2014 05:50 AM
I found out that the firewall team had enabled ALG (application layer gateway) services on a box between a few tandberg units and the gatekeeper. After disabling the ALG for H323 and RAS all returned to normal.
09-17-2014 12:49 AM
Hi Jonas,
can you check for disconnect cause under xhistory logs for endpoint which got disconnected ?
login to codec ssh, type xhistory.
it will give you complete call logs along with disconnect reason and cause.
