You start by reviewing the logs on each component, to find out where it's failing.
Review the logs on EXP-E, if you don't see the call, go to EXP-C, you don't see the call, back to CUCM.
If you're troubleshooting something, you need to look at the logs if you don't see anything in the search history.
Once you find the call, look at what's happening, and then if there's something wrong, look at your config, and confirm you have what you need, if not, adjust as necessary.
java
if this helps, please rate
