05-20-2021 06:14 AM
Will the a P60 and a Track60 (3 camera's in effect) work with the Room Kit Pro Codec?
Solved! Go to Solution.
05-26-2021 06:48 AM - edited 05-26-2021 06:51 AM
Hi Vic,
You can definitely do this with the RK Pro. Take a look at the admin guide page 82:
You'll see they show the presenter camera using one of the three generic HDMI inputs and you'd connect the ST60 cameras to the first two. Look at the inset picture on the right - that is exactly your scenario - audience cameras (ST60) on the camera ports and presenter camera on the next one.
05-20-2021 08:31 AM
What you mean by 3 camera ? If you have one p60 and tracker it’s two camera. If that’s the case, kit pro can have two camera control so it’s possible to handle p60 and tracker 60 together.
05-20-2021 08:39 AM
Hi Nithin
Apologies we have 3 possible cameras in view the P60 Speaker Tracker (CTSSPKER-TRACK60) has 2 inputs and the
standalone P60 1 input. Therefore 3 cameras. Is this scenario possible.
Vic
05-20-2021 10:38 AM
I never worked with p60 speaker tracking, the guide shows two camera control port on p60 speaker tracking . Since CS kit pro has only two camera control port I don't think its a right solution. Why don't you use Quad Cam, It need just one camera control connection.
Hi Vic,
