PASSTHRU OPTIONS FOR WEBEX ROOM KIT PLUS
Does anyone have the cisco powerpoint describing setting up the passthru options for the webex room kit plus, kit pro ?  I believe one option was using the vaddio a/v bridge.   Looking for cisco's recommendations for setting up passthru ..
Sir,
Sorry for the delay ... your input helped very much ... Thank you.
Jonathan Schulenberg
It’s in the zip file for the USB Macro; however, you can use Call from Laptop in RoomOS 11 to avoid the actual macro.
Sir,
