POE Mode B (midspan) devices can be powered directly on C2960X-48FPD
I have an POE device that needs to receive power on pins 4, 5, 7 and 8 (Mode B/midspan), but when I connect this device on my WS-C2960X-48FPD-L nothing happens.
Do you guys have a clue if this Mode B (midspan) it is supported by this switch model or/and if I have to make any special configuration ?
Best Regards,
Harsha A.
I believe it does support.
When you connect this POE device to the switch, what is the status of the interface ?
Did you turn on the POE feature ?
Switch(config)#int gi 0/1
Switch(config-if)#power inline auto
Switch(config-if)#exit
Harsha
Hello Harsha.
Tks for your reply.
When I connect the device the status remains down down.
The "power inline auto" is the default state, but I also configured "power inline auto" and "power inline static" for test purpose and nothing happened.
Mauricio
