POE understanding for Linksys SRW208P (is that 100% the SF302-08P ?)
ciprian.dascalu
Hello everybody,  I buyed by E-Bay a Linksys SRW208P (seems to be the same as SF302-08P) .. the item is on the way to me...
and now I read that the POE power is 15W on 4 ports OR 7.7W for each one from the eight ports ... I have 6 IP-Cams with 9Watt each...
How should I understand that... 7.7W x 8 Ports = 61,6 W ... Should I hope that if the POE power for 6 ports remain under
60W (9W x6 =54W) the cams will get the necessary current, or is there in the switch configuration something like an individual  protection per port and if
the power per port will be higher than 7.7W will drop out the poe-power supply on that port?
THX
best regards
ciprian
Jaime Valencia
This is the Video Over IP forum, and generally Linksys products are not covered in this forums.
A simple google search has the right forum for this
http://community.linksys.com/?category.id=English
java
if this helps, please rate
