04-05-2013 12:04 AM - edited 03-18-2019 12:53 AM
Hi All,
if you would give an advice I will be glad.
when an endpoint that is registered to CUCM-8.6.2.21900-5 makes a conference on MCU MSE 8510, the sharing presentation is shown on the media channel it does not use content channel. However same endpoint is registered to VCS-X.7.2.1 and make SIP call to MCU there is no problem, the media and presentation channels are different.
Endpoint SIP Call-->CUCM-->VCS-->MCU - media and presentation are on same channel.
Endpoint SIP Call-->VCS-->MCU - media and presentation are on different channel.
Thank you.
Solved! Go to Solution.
04-05-2013 12:09 AM
Hi Onur,
Take a look at the following document -
Page 46 shows you what you'll need to modify to get the BFCP working between CUCM and VCS
Guy
04-05-2013 12:09 AM
Hi Onur,
Guy
04-05-2013 12:31 AM
thank you Badman,
but in our config the BFCP is enabled.
04-05-2013 12:38 AM
ok, can you give us more information on how the advanced zone profile for the link to CUCM is set up on VCS?
04-05-2013 12:58 AM
because of working hours I can not change the profile,
on an appropriate time I will try this
Thank you
04-11-2013 10:49 PM
Badman thank you so much,
it is working.
