Showing results forĀ
Search instead forĀ
Did you mean:Ā
Probleme With FXO Card
oelmassaoudi
Hi All,
I have a problem on  FXO card. And I think that it is problem of configuration
I call numbers of line connected in FXO card, and I take down the call before the IP Phone answers me, the IP Phone continues sounded without stop, (approximately 120s)
Here configuration of chart FXO:
voice-port 0/1/1
no battery-reversal
output attenuation -6
cptone FR
timeouts interdigit 2
timeouts call-disconnect 0
timeouts wait-release 1
connection plar 130
impedance complex2
Thank you for your Help
Aaron Harrison
Sounds like a Supervisory Disconnect problem - you may also find that if you hang up the outside line after you have called, it doesn't disconnect promptly either?
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00800ae2d1.shtml
What country are you in?
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
oelmassaoudi
thank your for your answer
iam from morocco
OK, so I've not done this in your country...
Your best option is to go through some trial and error using some of the options in that document I posted. Apply one config, then shut/no shut the port and test it again.
Aaron
paolo bevilacqua
To begin with, use "connection plar opx".
