Process to Upgrade Firmware on DX80 registered via Expressway MRA
jaymegwin
What is the process to upgrade a DX80 registered via MRA - it exists in CUCM, however, upgrading the usual way by entering the new Phone Load name does not work.  Unit does not proceed with the upgrade.
ccoria
Currently, upgrading firmware though MRA is not supported.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvb29314
Regards.
Any advice or information on how to "Move the Load server" externally?
Justin
Thank you,
Justin Ferello
Technical Support Specialist, ScanSource KBZ
