Program a shutdown on a SX20
Afternoon!
I've been having a look on my SX20 web management (TC6.3.0.3d8e7d1) about programing a shutdown but I didn't find any menu for it, is it possible?
Best regards.
amehla
Hi Eduardo,
you can shutdown  your SX20 through the web interface.
you will get this option under Maintenance>restart>shutdown telepresence device.
In addiition to Amit's response above, you can use the API to do this with the following command:
xcommand Boot Action: Shutdown
You can send this via the command line (ssh/telnet), or though the web interface (Configuration > API).
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
  Great support.  This is very useful in terms of remote management. anyway, those API commands for a interface is   local to that device, am i right?  how this API can be useful if i use a easier interface for my IT Support to remote management or anything else? does TMS also has API exposed to do this?
You should be able to get your "easier interface" to telnet or ssh in to the device and issue the xcommand.  You can also do it via XML (see http://<IP Address of Codec>/command.xml).
Wayne
Wayne
