11-18-2013 08:33 AM - edited 03-18-2019 02:09 AM
Afternoon!
I've been having a look on my SX20 web management (TC6.3.0.3d8e7d1) about programing a shutdown but I didn't find any menu for it, is it possible?
Best regards.
12-01-2013 06:50 AM
Hi Eduardo,
you can shutdown your SX20 through the web interface.
you will get this option under Maintenance>restart>shutdown telepresence device.
01-06-2014 05:30 PM
In addiition to Amit's response above, you can use the API to do this with the following command:
xcommand Boot Action: Shutdown
You can send this via the command line (ssh/telnet), or though the web interface (Configuration > API).
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Please remember to mark helpful responses and to set your question as answered if appropriate.
03-25-2014 08:35 PM
Great support. This is very useful in terms of remote management. anyway, those API commands for a interface is local to that device, am i right? how this API can be useful if i use a easier interface for my IT Support to remote management or anything else? does TMS also has API exposed to do this?
03-26-2014 04:17 PM
You should be able to get your "easier interface" to telnet or ssh in to the device and issue the xcommand. You can also do it via XML (see http://<IP Address of Codec>/command.xml).
Wayne
